Old 12-04-2006, 05:21 PM   #1
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
How to remove the Nut on the top of the shock tower
here's a pic - how do I remove this nut. can't put both a box+allen key and the 17mm wrench simply doesn't fit
how to do this
hystria is offline   Reply With Quote
Old 12-04-2006, 05:55 PM   #2
YamilR
YamilR's Avatar
It will fit trust me, just have some patience
Old 12-04-2006, 06:33 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Read my reply to your last post in the Tanabe Spring Install post..
Old 12-04-2006, 06:40 PM   #4
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
use a offset ranch or use a impact ranch
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 12-04-2006, 07:08 PM   #5
hystria
hystria's Avatar
that looks like the rigth idea... appearantly the normal box wrench doesn't grip enough on the nut... a little pull and already slipping off
Old 12-04-2006, 08:16 PM   #6
YamilR
YamilR's Avatar
Have you ever seen the space for the strut tower? Its a pain to get a wrench in there let alone an impact "ranch"
Old 12-04-2006, 08:24 PM   #7
Chris07LB
Chris07LB's Avatar
Exactly... this is how its done, maybe get a better wrench.
Old 12-04-2006, 08:57 PM   #8
hystria
hystria's Avatar
thanks, finally I put a normal socket and gripped it veeery solid with the wisegrip then turn it - that worked
Old 12-07-2006, 03:20 PM   #9
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
well take a extra 15min remove the black piece and the wiper motor, that's how i put my impact ranch in.
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Tanabe DF210
JDM LED Tail lights
Old 12-07-2006, 04:35 PM   #10
Chris07LB
Chris07LB's Avatar
WRENCH. it's impact wrench.
Unless you're a cowboy, leave the ranch for horse's and salad.
Old 12-07-2006, 04:43 PM   #11
YamilR
YamilR's Avatar
Old 12-04-2006, 11:16 PM   #12
with or without ranch dressing ?
Old 12-04-2006, 07:25 PM   #13
skc
skc's Avatar
Drives: White5drRS
i got mine out with 17mm offset wrench..and allen key
don't strip the nut.. it will be pain in the ass..
skc is offline   Reply With Quote
Old 12-04-2006, 07:58 PM   #14
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
an offset wrench works.
Ive also had success in the past with a socket (similar to a sparkplug socket) that has the hex at the top and use a wrench on the socket and the allen through the top of the socket.
mikeukrainetz is offline   Reply With Quote
Old 12-05-2006, 12:39 AM   #15
SmellyTofu
好多人&
Drives: .
Rattle gun... after I took off all the wiper motors and trim. Come straight off.
SmellyTofu is offline   Reply With Quote
Old 12-05-2006, 08:48 PM   #16
Chris07LB
Chris07LB's Avatar
...he got it already.
Bunch of funny names for the same tools though.
Old 12-07-2006, 09:27 PM   #17
Black Yaris
der Zeck
Black Yaris's Avatar
what is it with the Canadian and all there funny names for things?
Old 12-08-2006, 12:32 PM   #18
mikeukrainetz
Sometimes if the nuts / bolts are overlly tight you can link two wrenches together (box end of one wrench linked into the open end of the other) - provided you dont have a breaker bar. This works fairly well most times and ive never had trouble rounding off the heads of either the nut/bolt. The shocks on my truck when I bought it were probably still original circa 1970 and this method worked like a charm cause I didnt have room for a breaker bar.
Just watch your knuckles.
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
