Old 04-20-2006, 03:24 PM   #1
RallyYaris
RallyYaris's Avatar
Drives: Ford Windstar 1996
Unhappy Engine mods - why bother?
I have been interested in super/turbocharging a Yaris. However, I have read that the engine will not be able to handle any appreciable extra horsepower without internal mods. So why bother getting CAI, exhaust mods, etc. if it will only add up to about 5 hp increase? It seems it will cost a lot of money to get the Yaris into the 150 hp range.
I guess I need to decide whether or not I want fuel efficiency or power. I wish they would put a slightly larger engine that could handle a turbo.
RallyYaris is offline   Reply With Quote
Old 04-20-2006, 03:34 PM   #2
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Supercharging it up to around 130-140hp combined with chopping off a lot of weight (which would be pretty easy) should give you a pretty decent power-to-weight ratio. What sort of ratio were you looking for?
Idjiit is offline   Reply With Quote
Old 04-20-2006, 04:30 PM   #3
RallyYaris
RallyYaris's Avatar
140 hp would be great, but I would seriously worry about the reliability of the motor. Wouldn't you need to get stronger internals to keep up with the extra power?
Old 04-20-2006, 04:31 PM   #4
jcove
jcove's Avatar
Drives: 2011 Rogue
Anything more and you would, but 140 should be fine from what I've been reading. Check out the thread on the Blitz.
jcove is offline   Reply With Quote
Old 04-20-2006, 07:20 PM   #5
birdy
I stay G'd Up
birdy's Avatar
Drives: 02 wrx wagon
Send a message via AIM to birdy
i think with this motor just get intake exhaust and header and be done with it and then get coilovers, sways and kick ass
birdy is offline   Reply With Quote
Old 09-26-2006, 03:59 PM   #6
w1ngzer0
w1ngzer0's Avatar
Drives: Subaru Impreza
Don't forget engine management
w1ngzer0 is offline   Reply With Quote
Old 04-20-2006, 09:32 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Any type of serious adding of power, like forced induction, will shorten engine life.
The choice is always between mpg or hp.
However, a new intake, a full exhaust system, lightened flywheel, etc, things that will free up hp by removing restrictions and weight should not shorten the life of the engine.
Colin Chapman disciple
Old 04-27-2006, 05:27 PM   #8
AutoTech1
Drives: None yet
You can about cut your engine life in half with forced induction... Maybe more. With the yaris, I wouldn't even think about forced induction, unless you have the money for internal upgrades.
I like the idea of less wieght. Less rotating mass on the crank. Decreasing wieght and rotating mass is about the best modification anyone can do for a car, and it is often over looked. It does not destroy the engine. If anything, getting lighter parts are just that. They are lighter, but weaker. You're better of breaking a flywheel than a few pistons or rods...
The yaris can be a very agile car if it's balanced the right way with modifications. In a car like this, I'd shave lbs, perform bolt ons and do whatever it takes to increase power without turbocharging/supercharging. I'd also correct the suspension and brakes. But I'd end up writing a good amt. There are many ways to gain power... Not only through forced induction or giggle juice (nitrous, alcohol, Co2 etc).
If I bought this car though, the best bet would probably be to machine the engine. Send it to a private shop. N/A modifications are always great. They are just costly as well. :-P I wish I could say more, but that's all I can think of off the top of my head, since it's only my first year of Auto Tech so I only know so much. :-)
But remember this. If you perform a good amount of N/A modifications, you may want to consider crossing over to Forced Induction afterwards... This gets crazy with explaining, but you have no clue how many ways you can get power from a car.
AutoTech1 is offline   Reply With Quote
Old 08-07-2006, 11:02 PM   #9
captainzerocool
CAMRY FTW!
captainzerocool's Avatar
Drives: Camry LE V-6 (225,000+ miles)
Those mods will EXTEND the life of a well maintained engine as well as add more power.
I drive a Camry.
I have no imagination.
captainzerocool is offline   Reply With Quote
Old 04-27-2006, 11:39 PM   #10
why?
why?'s Avatar
Drives: Yaris LB
Lighter parts are not weaker. That would be stupid.
F1 parts are the lightest parts any vehicles use. They are also some of the strongest. F1 engines spin to 20,000 or so rpms.
It will cost more money, but it would be worth it. Every pound you can take out of a car means better gas mileage, handling, braking, acceleration, etc.
And the best thing is Yaris engines only make 106 hp. I bet it would be hard to find a part too weak to handle Yaris like power.
Old 04-28-2006, 09:55 PM   #11
AutoTech1
Drives: None yet
Ok. Before you jump ahead, let me point out, which I might not have, that I did not say "All light parts are weaker." That statement would be completely false. When you are looking into many interior components within the block, and you are going in the direction of racing, you can't simply be paying more for parts when they are not any stronger. These parts will be stronger. And more often, they'll be forged over their stock counterparts proving your argument true. A lot of internal parts are built strong, because it's torque that deals a blow to anything in the block, which is why aftermarket parts are made stronger for the engine. And when you force more air into the engine, this increases torgue; that is, if you are adding the right amount of fuel to get the best stachiometric ratio for performance.
As for some other things, take a flywheel for example, it is not built in mind for as much of a strength purpose. It's basically to decrease rotating mass. And you may wonder why? Well, if you decrease rotational mass, you decrease resistance and you free up tiny amounts of horsepower. Consider this... You can rotate a crank from nascar with two fingers... Could you ever do that on a yaris or a stock car of any kind that is not dedicated to a race track? Probably not. Kind of like what N/A modifications aim to do. Now that's not to say, that they (flywheels) aren't stronger than stock counter parts. They most likely are. But these parts are made for lighter wieght purposes and you can still break them under a lot of stress/torque.
And take a drilled rotor for example, to prove me right. Drilled rotors do nothing for stopping purposes. They are drilled to reduce wieght. With these drilled holes, they make the rotor weaker... Which is why you have to ask yourself, why even bother getting drilled rotors for a street application? Many do it. Now that's not to say again, that they aren't stronger than stock components. Most often than not, they are... But they are still weak... And that's what I'm saying. Anything that aims for a lighter wieght purpose only, is going to be weak... "Torque fighting modifications" will be stronger though... But keep in mind, everything is only stronger to a certain point.
Which brings me to an interesting fact. Bolt grades. To get a point across, some bolts are built weaker on purpose. Take a lawn mower or a machine of comparible size with the same purpose. Let's say that your blade binds up. Some of these machines have weaker bolts connected to this blade, so that you break the bolt, and not the blades... In other words, break a small thing to protect a large investment. And for other applications you have stronger bolts... For the obvious fact that you don't want the bolts to break.
Any you're right. The Yaris can't break too many things yet with the torque it makes. It's not so much hp... But torque that kills an engine... I was talking about higher powered cars... But still, I wouldn't run forced induction on the Yaris, unless you consult a professional and get the right parts to rebuild an engine before doing so.
Old 04-29-2006, 01:07 AM   #12
C2AUTOSPL
Drives: 240sx, 00 Celica
Market rightnow is very small for the Yaris. We'll see what the future holds.
C2AUTOSPL is offline   Reply With Quote
Old 06-06-2006, 12:22 AM   #13
YarisHatch
Drives: Blank
Send a message via AIM to YarisHatch Send a message via Yahoo to YarisHatch
Its all about power to weight. On a 2,200lbs car, 110whp is going to produce acceleration much differently than a 3,000lbs car. People get too caught up on dyno numbers that they loose sight of what car those numbers are on.
Also, when boosting any original n/a motor, its always best to upgrade the internals no matter what psi you plan to run on in terms of daily. Because in the end, you'd rather over-build the motor/tranny than underbuild. At least, thats the way i think.
YarisHatch is offline   Reply With Quote
Old 06-06-2006, 05:29 PM   #14
Snake
Send a message via AIM to Snake
if you want any real power on the yaris, just drop in a 2zz (1.8) motor from a celica or
a 2AZ-FE 2.4 from a scion tc, the stock yaris motor is not really good past 170 crank hp on boost without heavy internal block work
if you guys look into it, these swaps should really not be that difficult and they are inexpensive enough to find at a junkyard, plenty of aftermarket turbo kits for both motors with the celicas and tc's running around
Snake is offline   Reply With Quote
Old 06-06-2006, 06:21 PM   #15
YarisHatch
Drives: Blank
^Prime example of what i was saying earlier, its not about the numbers. And zpi has pushed 181whp on their 8psi turbo kit, they have been running it hard the past 8,000 miles without any trouble. Its possible to make decent numbers if thats what your after.
The 2az is crap. The internals are a joke on it, it would also cause the yaris to have a very uneven weight dist. with that much weight added to the front end. Also, the 2zz is a better n/a motor than a boost motor. Not to mention, the transmission on the 2zz is seriously weak. One mis-shift on a boosted motor and you will cause minor to significant damage. Its been proven in the past with celicas. While i'd love to see a 2zz in the yaris as well, that transmission is a no no. N/a, you can make some good power out of it if your willing to take the time, and money to invest naturally aspirated vs. throwing down a few thousand for some easy power.
Another thing you might want to realize when you talk motor swaps, the yaris engine bay is pretty small. Its smaller than the xb's, and a 1.8l can fit in the xb but without some adjustments to the firewall. Putting a 2.4l would be a huge project, can be done but wouldn't be easy. Also wouldn't be practical because with the weight added, it would handle like crap and can even be dangerous, especially in the rain.
Old 06-06-2006, 11:27 PM   #16
Snake
this is why they have 2az's with internal race mods pushing 540+fwhp on scion tc's
lol
all the 2zz needs is a set of 9:1 comp ja pistons, and you can run all the boost you need
anything can be done, if you know what your doing
if I could push 600+hp out of a neon, im sure u guys can play a little bit with a yaris and actually get a little bit of power so leave all options open to play
just need some proper fuel management and tuning so you dont blow your shit up and some $ for a good setup
Old 06-28-2006, 11:07 PM   #17
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
thats about the coolest thing ive ever seen...
mikeukrainetz is offline   Reply With Quote
Old 06-29-2006, 12:37 AM   #18
weeze-dog
Drives: 2002 Ford Focus ZX3
Pluuuuulllllleeeeeeaaaaaseeeee, 13.40 quarter mile in a Ferrari F430? He obviously can't drive, cause that is HORRIBLE. A stock late model camaro can do 12.90s with just an exhaust and a good driver. He bogged it off of the line bad.
For the record road and track got 11.7 in the quarter mile in their F430.
Link
I believe they say every tenth of a second is one car length, he should have been 15 car lengths ahead easy. Guy in the smart better be glad he didn't wreck cause that thing was gutted so much it had the strength of an aluminum can.
You want to see impressive, watch the video of the turbo mini-van pulling a wheelie off of the line and beat a V8 transam. Now that was impressive. Too bad I can't find that old video anymore.
Edit: Ah Ha, here's one of the videos. This van runs a 12.65 in the quarter, better than the ferrari and smart car by almost a second. Now THIS is impressive.
Turbo Mini-Van
weeze-dog is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Mod's List riceboy General Yaris / Vitz Discussion 43 07-25-2006 09:49 PM
How strong is this engine? UndefinedDesign Performance Modifications 27 07-08-2006 09:45 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
engine modify for d-4d uraz General Yaris / Vitz Discussion 0 02-20-2006 02:16 PM
