Old 09-06-2010, 03:27 AM   #1
henry33
Drives: yaris1.33
driving on Low RPM
is driving on rpm lower than 2000 hurting the engine or damaging something ?
I have 6 speed manual trans.
thanks
henry33 is offline   Reply With Quote
Old 09-06-2010, 04:34 AM   #2
Pingouin
Drives: Yaris
I'd like to know as well. With my focus, I could happily move along at 1500RPM ish or lower, but my Yaris feels like it's struggling. I could also change gear at 2000RPM on the Focus, but the Yaris feels unhappy unless I hit 3000RPM.
I should try harder as I'm not going to save on petrol if I always have to rev higher :(
Pingouin is offline   Reply With Quote
Old 09-06-2010, 07:16 AM   #3
henry33
Drives: yaris1.33
I was accustomed to do the same but have read somewhere that it is not good for Yaris engine
Old 09-06-2010, 01:21 PM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
No, it won't hurt a thing.
Old 09-06-2010, 03:19 PM   #5
henry33
Drives: yaris1.33
glad to hear that thanks hilton
Old 09-07-2010, 04:13 AM   #6
tidus1203
Drives: 2009 Yaris 1.5 M/T 5dr.
What's important is it does not lug, you know the engine vibrates due to lack of power on a given gear... If it does not lug then you're fine...
tidus1203 is offline   Reply With Quote
Old 09-07-2010, 05:11 AM   #7
henry33
Drives: yaris1.33
no the engine is able to run at 1500 rpm very smoothly and have enough power to accelerate without shifting down so it should be ok ;)
Old 09-07-2010, 12:19 PM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
+ a bajillion. It will take time getting use to the Yaris, especially coming from a high torque car, but the Yaris runs fine in the low rpm ranges. I shift at 2000 rpm's and try not to ever go higher, and my car runs fine.
Colin Chapman disciple
Old 09-08-2010, 01:12 AM   #9
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
4-holers don't like to lug, and what is lugging is unique to every engine. I never push my Yaris below 2 grand, and it cruises fine at 1500. RPM isn't that big a problem for fuel economy, it is throttle opening that hurts...
Old 09-08-2010, 03:27 AM   #10
Pingouin
Drives: Yaris
I can confirm that my Yaris coasts fine at 1500RPM (in fact isn't it when the eco thingy that cuts off the petrol to save it goes off?) and I can change speeds at 2000RPM alright. It's just that coming from a 1.6L petrol car, the Yaris lacks serious punch when doing so. But I guess I can't have both that and high MPG! :D
Mind you, I leave in town, so I don't really ever need to floor it! Can't go much faster than the car in front of me, can I?
Old 09-08-2010, 03:50 AM   #11
henry33
Drives: yaris1.33
Tlyttle : how do you know when the throttle is opening ?
PIngouin : the same situation I am living in the city and when you have car in front it is hard to floor it down :D usually I am cruising at 50-60 km/h :)
Old 09-08-2010, 09:51 AM   #12
bankrobber
Drives: 2007 Yaris Hatchback
Throttle is open when gas pedal is pushed. Not a mechanic here but I dont think fuel injection has a throttle. It's all electronic right?
bankrobber is offline   Reply With Quote
Old 09-08-2010, 10:54 AM   #13
Yaris Hilton
Smile
If you don't hear knocking and the car doesn't shudder, you're not "lugging" an engine.
Old 09-08-2010, 01:53 PM   #14
RedRide
RedRide's Avatar
A little common sense can go a long way. How low you should go on the RPMs is dependant on the gear and if you are going uphill etc.
Understanding this is part of driving.
One can get a feel if you are "luging" an enging and then, shift acordingly.
Lugging an engine can put more stress on the wrist pins, con rod bearings etc. It just simple, basic physics that it does. I'm not going to debate any one who says it doesn't.
The only thing that is debatable is at what point you are indeed lugging the engine and that point can only be determind by the imediate driving conditions, not by some sort of chart or table etc.
Old 09-08-2010, 02:10 PM   #15
detroiter
detroiter's Avatar
You'll know your lugging the vehicle just as Hilton stated, you'll have next to no power/pull, car will be shuddering and feel like it's gagging to stay alive. As long as the car is running and pullin smooth, your smooth sailin
Old 09-08-2010, 02:19 PM   #16
RedRide
RedRide's Avatar
It's not a question of the enging running "smooth". Modern ECUs will always adjust things (timing fuel,etc) to make the enging run smooth.
The issue is subjecting the wrist pins, con rod bearings etc, to extra stress. Like I said, it's simple, elementry physics.
Old 09-08-2010, 02:21 PM   #17
detroiter
detroiter's Avatar
Modern ecu or not, a car on the verge of stalling due to being lugged is going to happen regardless. So if what your saying is true, then your car would be running smooth at 200 rpms while it's choking to death going down the road. I don't see that happening.
Old 09-08-2010, 04:13 PM   #18
RedRide
RedRide's Avatar
Well, of course you are going to stall the engine sooner or later. That is not the issue at hand.
I assume we are all "smarter than a fith grader".
I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe PETERPOOP Off-topic / Other Cars / Everything else Discussions 21 05-16-2010 03:19 PM
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Getting used to driving small cars... orangepeels General Yaris / Vitz Discussion 19 05-06-2009 12:45 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
driving harsher..... hoahmaru General Yaris / Vitz Discussion 7 04-09-2006 02:59 PM
