Old 09-17-2010, 10:16 PM   #1
Hershey
Carelessness of some TOYO mechanics ;
Decided to take a look at the air filter and try to find any oil leaks before changing the oil after the recent head gasket replacement of the '08 sedan . When we got the car back about 2 weeks ago I checked the dipstick on the next day and found that it read over a 1/4 of an inch above the FULL mark . Would think that to be a 1/2 quart overfull . Then kept an eye out for any oil leaks from the new F.I.P.G. sealant and nothing as of yet . Then earlier today I put the car on ramps to get a better look for any leaks and discovered the oil filter they had installed had oil on the bottom of it and that it was not tightened properly as where I could easily unscrew the filter . Then checked the air filter that was installed in APRIL and found it to be filthy . Looks like they set the upper part of filter ( side of throttle body ) on a dirty work bench or threw it on the grimy floor . Thus I had to find the old air filter and clean it with a vacuum cleaner and install that one in which will be replaced by a new one that we'll pick up tomorrow . Then I decided to drain the overfilled oil that may have sealants in it from the head gasket replacement and put on a new TOYO oil filter . Now reads at the FULL mark . Concerns us of what we can't see that was performed by the mechanic(s) . Here's some pics of the dirty air filter and the oily bottom of oil filter ...
Comments on Toyo Perf. Tires please MUSKOKA800 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-25-2013 08:11 PM
Any oldschool obd1 mechanics here i need help with a diagnosis YarisSedan Off-topic / Other Cars / Everything else Discussions 28 03-28-2009 07:24 PM
Toyo Tire R888 deals with ubcscc.com BC only mojoyaris Canada 0 01-25-2009 04:49 PM
BFGoodrich g-Force KDW2 or Toyo Proxies 4 - any opinions.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-15-2007 09:02 AM
FS: 4 215/50/15 Toyo Proxes Snake Items for Sale by private party 0 01-15-2007 11:13 AM
