Old 09-01-2010, 06:05 PM   #1
2manywheels
Drives: 09 YarHB
Track setup.. tires/psi etc
Out to the track tomorrow.
Not an autocross. But full sized with a 1/2mile straight away.. and some decent fast corners..
Besides checking everything over(torque/brakes/lines safety etc..)
What should I start with for tire pressures?
Supposed to be 20 degrees tomorrow and dry.
Cold, they are currently 32.5psi(Dunlop Direzza's) 205-50-15's on the 15"x7 Enkei RPF1's.
I have a tire temp guage I will be checking between runs to check for higher heat on different parts of the tire etc.
I have never taken a FWD car around this track. Only rear drive ferarri's and vettes.
Any thoughts or suggestions?
2manywheels is offline   Reply With Quote
Old 09-01-2010, 07:01 PM   #2
Start with manufacturer pressure and adjust from there, even if it means pulling over during a session. You'll know after a couple of laps and they heat up what's happening with your tires and over/understeer, softness, etc.
Old 09-01-2010, 08:59 PM   #3
nemesisz
559 Before the Hack
nemesisz's Avatar
Drives: 07 Yaris LB
My experience with the same setup (Star Specs 205/50 + RPF clones) was great. I ran a track day (4 30 minute sessions) at Homestead Miami Speedway with ambient temps of 94 and track temps of 105+. My pressure was initially set at 42psi all around. It was set and forget. I ran all day with great tire wear and no tire melting or grip reduction.
If I were to do another day there with the same temps I might reduce the pressure in the front to 38-40psi. Infamous Turn 10 is the only place where more rear rotation may not be the ideal setup.
nemesisz is offline   Reply With Quote
Old 09-01-2010, 10:55 PM   #4
2manywheels
Drives: 09 YarHB
THX Garm/Nemesisz!
Old 09-02-2010, 07:49 PM   #5
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
How did you do ?? I run 38 in the front and 42 in the rear and I only have to adjust them once after they warm up. Sorry I didn't catch the first post but the company sent me to Wichita for a few days.
soloecho2 is offline   Reply With Quote
Old 09-03-2010, 12:36 PM   #6
2manywheels
Drives: 09 YarHB
Suprisingly well!
37.5 front and back eventually. After a few sessions/hot laps. brought them down from 40ish. The Dunlops were great. Might consider the 23/24mm Sway bar for next season. Supercharger will be a welcome addition in the straights. Video is being posted on youtube now. Will update a link later. Hopefully I didn't swear too loud while ripping around!
Old 09-05-2010, 03:15 PM   #7
2manywheels
Drives: 09 YarHB
short vid.. :P
http://www.youtube.com/watch?v=ytQWt0zwHGY
Old 09-06-2010, 08:16 AM   #8
nemesisz
559 Before the Hack
nemesisz's Avatar
Drives: 07 Yaris LB
Great video. I really like the sunset reflection in the windows.
How fast were you going in the straights?
Old 09-06-2010, 09:30 AM   #9
2manywheels
Drives: 09 YarHB
About 165km/h I think I might have put a dent in the floor board from having the pedal mashed against it for almost 3 hours...
Old 10-05-2010, 08:33 PM   #10
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I find that optimal tire pressure varies between tires. On my NT-o1's I run 30psi cold all around. On my R1R's I run 28 cold in the front and 34 cold in the rear to get the same balance. Also depends on your suspension and alignment. If I was on stock suspension and factory alignment those pressures would be too low. So it really comes down to what you find best.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 10-06-2010, 04:17 AM   #11
jetbtkng
idiot racing team
jetbtkng's Avatar
Drives: 2010 hatchback
now this is for my solara i use toyo r888 & i start out 38 front & 36 back, after the 1st session i check pressure & when there hot i lower pressure to 48 front 44 back the weather usually in the 90's-low 100;s high, heres a vid http://www.youtube.com/watch?v=1pLigAQIFzw
jetbtkng is offline   Reply With Quote
2010 12th Touge.ca Track lapping - September 5th Mosport DDT Lapping event!! Touge.ca Canada 1 08-24-2010 03:01 AM
This coming Sunday Aug 1st -Cayuga (TMP) Track lapping event, 2010 9th Touge.ca event Touge.ca Canada 12 08-06-2010 06:19 PM
July 24th Cayuga TMP track lapping event, 2010 8th Touge.ca event Touge.ca Canada 0 07-16-2010 12:05 AM
June 5th Cayuga TMP track lapping event, 2010 4th Touge.ca event Touge.ca Canada 0 05-30-2010 04:37 AM
August 16th Cayuga TMP track lapping event, 2009 11th Touge.ca event Touge.ca Canada 2 07-30-2009 03:19 AM
