Old 10-16-2010, 12:40 PM   #1
sleey0
Drives: 2008 Yaris LB
Just curious...
I heard from a little birdy that fixed pulley sc are coming for the yaris, not the blitz.
Is it possible to use a boost controller to control a supercharger?
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-16-2010, 12:43 PM   #2
maxxman420
prop215.
maxxman420's Avatar
Drives: Toyota Yaris LB
im really not sure, but i dont think you use boost controllers on superchargers. its the size of the pulley that controls the boost. im not sure, but i think thats how it works.
maxxman420 is offline   Reply With Quote
Old 10-16-2010, 02:38 PM   #3
severous01
you could do a blow off valve, just like a turbo. they're actually teh same thing (cintrifugal any way) so, the pulley supplies the boost amount, but if you're over the amount you want you can BOV it just like a turbo
but it's easier to dial in SC pressure with pullies because it will always spin and produce pressure at the same amount at the same rpm at all times...not like turbo that depends on exhaust which always changed depending on load and rpm...as well as temps and all sorts of things
any way, if you got too much boost BOV it.
Old 10-16-2010, 02:51 PM   #4
No. A waste gate controls boost, not a bov. I can run 8 psi and I can run 30 psi with the same bov and no changes to it.
Old 10-17-2010, 03:51 AM   #5
^. That's the same function as a waste gate on a turbo system, right?
Old 10-17-2010, 01:16 PM   #6
xbgod
Drives: "Burning It Down GTX2860RS XB"
Yes thats right a waste gate, just like the one I put on the Blitz S/C with a custom pully.
I used a custom fit one from Magnuson.
Aras
xbgod is offline   Reply With Quote
What age are people here? Curious what age group is buying this car. JDE General Yaris / Vitz Discussion 351 05-19-2011 04:28 PM
Curious about the Yaris Second to none New YARIS Purchase Forum 1 12-01-2008 10:37 PM
Curious about GB uncleyaris Canada 25 11-12-2008 06:32 PM
curious question yrsdrgn Cosmetic Modifications (Exterior/Interior) 19 02-04-2007 01:46 PM
