Old 10-08-2010, 03:58 PM   #1
Faraz_Shaikh
Drives: Toyota Vitz
IS IT SAFE TO RUN TURBO ON STOCK INJECTORS ?
Dear EXPERTS
ive purchased turbo kit for 1szfe
http://www.ninjapower.co.uk/product_...cp10-1szfe-bot
the problem is i'm having the stock injectors, link is under
http://cgi.ebay.co.uk/Yaris-99-03-1-...b#ht_782wt_911
kindly confirm if running turbo is safe on this setup, and also provide info that how much boost should i run on this setup, as i am installing intercooler as well.
Waiting :)
Faraz_Shaikh is offline   Reply With Quote
Old 10-08-2010, 04:53 PM   #2
severous01
no, you'll run lean and burn a piston/valve.
you might be able to run a few pounds...1-2 with no problems, but why add boost if it's only 2lbs?
Old 10-08-2010, 05:02 PM   #3
Faraz_Shaikh
Drives: Toyota Vitz
but how is it possible that hks has built so expensive kit for this engine without injectors? maybe the fcon controls all ?
Old 10-08-2010, 05:05 PM   #4
once the injectors reach 100% duty or even close, they can't squirt any more fuel. So no, the Fcon cannot change the laws of physics.
Anyone ask you what your air/fuel is, what your boost level is, and if you have gauges for both? Ok - I am.
Old 10-08-2010, 08:18 PM   #5
sleey0
Drives: 2008 Yaris LB
Im in a similar situation.
Need to know if.the 1zz injectors will run 12psl.
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-08-2010, 10:37 PM   #6
Focus_Sh1ft
Focus_Sh1ft's Avatar
You need larger injectors after 5 psi.
Old 10-08-2010, 11:05 PM   #7
sleey0
What is th next step up after 1zz? tC injectors?
xbgod - 9/23/2010
Old 10-19-2010, 02:32 PM   #8
TrashCan Monster
Drives: an egg
an upgraded fuel system is a must with any FI
TrashCan Monster is offline   Reply With Quote
Old 10-19-2010, 02:42 PM   #9
^ what does that mean?
Aside from injectors, I ran the stock fuel system at 8-9 pounds for over eight months. All the supercharger guys are running stock systems, Carlos and Charles both running stock fuel systems with their turbos.
Old 10-19-2010, 04:01 PM   #10
cdydjded
Drives: Yaris LB Turbo
That kit is discontinued. HKS is expensive because its from Japan.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 01:18 PM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
