Old 11-23-2010, 07:44 PM   #1
H3LlIoN
Drives: '09 Yarrrr hatch
Thumbs up Weapon-r sheet metal intakes 1/2 off (almost)
For black weds tomorrow, the weapon-r sheet metal intake for the xB is only going to be $350, as opposed to $600msrp. (Between 10a and 4pm, not sure on timezone.) The flange will bolt directly to the head on the yaris 1nz, although you will have to cut off the xB tb flange and weld on a new one to match the yaris DBW tb. Machine shop would probably charge ~$50 to do this, if you lack the skillset/tools req'd. You would also have to adjust for the new TB position in regards to intakes, as it will not be the same as the yaris. As the MI intake is as of yet incomplete, this is currently the only option, besides custom building an intake. Be sure to tell 'em I sent you. That is all.
link: http://www.weapon-r.com/index.php?ac...product&id=499
Aforementioned shiny object:
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 11-23-2010, 09:13 PM   #2
xbgod
Drives: "Burning It Down GTX2860RS XB"
70mm on mine baby
xbgod is offline   Reply With Quote
Old 11-25-2010, 07:12 PM   #3
weapon5
Drives: VITZ
what is the mod to install a 1zzfe tb on this?
weapon5 is offline   Reply With Quote
Old 11-25-2010, 07:21 PM   #4
H3LlIoN
AFAIK the zz tb is the same pattern as yaris, so same deal.
Toyota
Moving Forward
Old 11-26-2010, 03:34 AM   #5
weapon5
Drives: VITZ
so no need to enlarge the tb entrance on the manifold?
Old 11-27-2010, 12:21 AM   #6
H3LlIoN
no.
Toyota
Moving Forward
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 07:29 PM
New brakes/rotors - sounds like metal on metal rubbing salmonz DIY / Maintenance / Service 9 07-20-2010 08:46 PM
Metal on metal rotating wheel noise phyrefighterjay General Yaris / Vitz Discussion 7 04-19-2010 11:31 AM
