Drives: 02' Yaris Verso Join Date: Nov 2010
TP Sensor, or TP Switch?
Hi, I'm wondering if the tps on the yaris is a potentiometer type sensor or if its just a simple switch with "idle contact" and "wide open throttle" contact points.
I'm after a throttle position SWITCH for my old datsun and the yaris throttle opens the correct way. It's a 2002 model with a 1.3l engine. |
![]() ![]() Drives: 2010 Yaris ce Join Date: Jan 2010
The tps in the Yaris is a potentiometer
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 04:11 PM |
