Old 12-08-2010, 07:41 PM   #1
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
Sway bar link replacement
I had a rattle/popping noise in the front of my Yaris. So today the dealer said I need a new sway bar link. I asked why, they said the joint is loose. I asked them if they tightened the sway bar link, they said the the nut is NOT loose, so it's the joint that's bad. It's $170 for 1 sway bar link for an 07 Yaris Sedan. I checked myself and the nut/bolt turns together freely.
Is replacement the best course of action?
salmonz is offline   Reply With Quote
Old 12-08-2010, 08:25 PM   #2
DARK AGE 53
Drives: 2009 Yaris Onyx
sounds loose if you can turn the nut/bolt to me, have you tried tightening it? also, I just change one my HHR, cost of end link $35.
DARK AGE 53 is offline   Reply With Quote
Old 12-08-2010, 08:44 PM   #3
Is the rubber bushing worn out? How many miles on the car?
I probably have a stock one around.
Old 12-08-2010, 09:00 PM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
www.hrpworld.com you can make your own for less than that.
Originally Posted by xnamerxx
you nailed it sir.
Old 12-08-2010, 10:04 PM   #5
If I'm thinking of the correct part, there's a place on ebay that sells aftermarket ones for $22 each.
http://cgi.ebay.com/ebaymotors/Deeza...Q5fAccessories
Old 12-08-2010, 10:42 PM   #6
salmonz
salmonz's Avatar
Thanks guys!
Toyota dealerships are definitely overcharging.
ToyotaPartsCheap.com (Mossy Toyota in California) lists the part as $95US MSRP / $75 sell price link: http://goo.gl/1C5ZC
The dealership near me in Ontario is charging me $170 Canadian + 13% tax. The dollar is at par. 70% premium for the same part?
What's more likely to fail first? Toyota parts or aftermarket?
Old 12-08-2010, 10:44 PM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
toyota. aftermarket is gonna be urethane or better.
you nailed it sir.
Old 12-08-2010, 10:51 PM   #8
Thanks guys!
I was thinking that OEM parts are generally better, but Tamango is probably correct on the boot material. They are very easy to replace. When they are spinning though you have to use a pair of vicegrips to keep the bolt from rotating so you can get the nut off.
Old 12-09-2010, 10:30 AM   #9
MUSKOKA800
MUSKOKA800's Avatar
Call a local auto parts store.
When I did the end links on our 2003 Escape I got the identical parts from Canadian Tire as the factory parts being removed for about 1/4 the price of what the local Ford stealership quoted.
Those used an allen head wrench to hold the bolt portion from spinning while wrenching the nut off or on. It took less than a half hour to change both sides in my driveway.
$24.00 plus my 1/2 hour vs over $200.00 to let the dealer replace them (parts and labour). Ahhh, it's great to be handy.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
WTB: Sway bar end link thepoche Willing to Buy by private party 10 05-24-2010 02:24 AM
Rear Sway LINK BRACE djct_watt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-16-2009 04:29 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 07:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 12:52 PM
