love to drive
Drives: 2010 yaris sedan Join Date: Sep 2009
fuel filter
Are the fuel filters on these wonderful little cars in the gas tank?
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
That's what I've heard but not sure if it's true
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
On an ECHO yes they are. They are integrated with the fuel pump. Theres no requirement they be replaced either. I would think the same is true for the Yaris.
![]() Drives: 08 lb Join Date: Apr 2010
it is true for the yaris, hopefully no1 has to worry about theirs.
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
I think I had one go on my 2005 echo with 200,000km...
Basically i had to fill the gas tank up on the slowest setting at the pump. Not sure if it was the filter or something else. anyway it was impossible to fill the tank. |
Half a Bubble Off Plumb
That's a clogged tank vent hose, not the fuel filter.
Thanks Yaris Hilton...
how does the vent hose get clogged? |
A kinked hose, debris in the tank, deteriorating rubber inside the hose blocking the lumen... I recently had to replace the fuel hoses on a Diesel engine that had rotted and blocked themselves. My problems with vent hoses have been with cracking and leaking rather than plugging. I suppose you could have something in the filler pipe as well.
ahhh.... I understand now!
![]() Drives: 07 Yaris Join Date: Dec 2010
You don't have to change the fuel filter on a YARIS?
nopers.. i think its more of a strainer attatched under the fuel pump inside the tank. but no filter from the pump to the injectors
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
Most of the gunk in a gas tank is actually rust and corrosion from the tank itself. The Yaris has a plastic gas tank. No metal means no rust. Any fuel you put in should be getting filtered at the pump.
I personally like the idea of having a user changeable gas filter, but I've never actually needed to change one because it was clogged. Toyota obviously feels that the small amount of foreign matter introduced into the tank can be handled by the built in filter for the life of the car. Unless something goes dramatically wrong, they're probably right. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Change to high quality filter lead to drastic drop in fuel efficiency | lh59 | DIY / Maintenance / Service | 19 | 07-02-2009 02:22 PM |
| Fuel Filter | abbeyaris | General Yaris / Vitz Discussion | 35 | 03-22-2009 11:40 AM |
