![]() Drives: Yaris liftback Join Date: Dec 2006
How do I take apart dash on left side?
I'm trying to tap into the parking light wire on the fuse box which is a 30 pin on the upper left side. I can get the small cubby out in order to see the fuse box, but how do I remove the rest of the dash above the fuse box? Does it just pull out? I didn't want to force it and break something, the wife would kill me. I'm putting in a remote starter and I need a positive parking light wire, the one that comes off the headlight switch is negative. If anyone knows of another location I can tap into let me know.
What you need to do is search the forums for the Yaris Repair Manual. That thing will tell you all you need to know.
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
You don't need to remove the dash. Pull the 30 pin plug out find the wire and strip some insulation away and tap right in.
I tapped into all 3 door triggers, parking lights and the dome light wire without removing any part of the dash.
ChinoCharles Intake supporter. |
Thanks acrbill. I had looked at pulling it out but didn't want to fudge anything up. That's what I will do then.
be careful with the wires since they are very thin. I used one of those automatic strippers and I broke most of the wires I was trying to strip.
The best way (IMHO) to strip a wire with limited room/thin wires is "sawing" the plastic with a blade. The automatic stuff works for home installations and what not, but they make bad things happen to good people on thin wires :P.
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 03:59 PM |
| Are the optional airbags worth it ? | avenno2g7 | General Yaris / Vitz Discussion | 46 | 12-07-2008 02:40 AM |
| "Airbag" center console light on 07 Sedan with side airbags | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 11-10-2006 06:10 PM |
| Removing A-pillar/partial dash | H8SGAS | DIY / Maintenance / Service | 0 | 09-02-2006 09:03 PM |
