Old 10-15-2010, 10:24 AM   #1
Paris vvt-i
Drives: Yaris ts 1.5
yaris ts 1.5 turbo
Hello my friends!!
I have a yaris ts 1.5 2004. I am looking forward to turbocharge it!
My 1nz fe has the following and only changed components:
1) CP pistons 9:1 75mm (stock bore)
2) Crower rods and better rod bearings
3) stiffer valves and valve springs
4) toga engine bearings
soon i will get a walbro 255L/h fuel pump and larger injectors.
For ECU I will install a standalone Link g4 storm.
The turbo I chose is the Garret2554R. When I put the turbo I will also put denso iridium spark plugs.
My goal is to achieve maximum 230hp at the crank reliably.
As for the injectors I will get 370cc or 440cc . which of the two would you choose?
Paris vvt-i is offline   Reply With Quote
Old 10-18-2010, 03:19 AM   #2
Paris vvt-i
Anyone?????
Old 10-18-2010, 10:03 AM   #3
larger injectors for that power, you'll need them.
probably need a return line too. what turbo are you going to use?
Old 10-18-2010, 10:10 AM   #4
Paris vvt-i
Thank you. I will use the GARRET 2554R!
Old 10-18-2010, 11:21 AM   #5
230 bhp is about 210 whp, you should be fine with the GT2554R. Good luck with the project, that will be a very fast car.
Old 10-18-2010, 12:07 PM   #6
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
+1 with what garm said, go with the 440cc injectors just in case you're planning to upgrade your turbo in the future.
you can also check out this 1nz-fe here, the car made 200 whp using the GT2554R on automatic transmission with a meth kit and standalone ecu.
by the way, hi garm long time no see! :)
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 10-18-2010, 01:48 PM   #7
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
Yeah, nice idea. I've been contemplating on boosting my Yaris for a Loooooong time, I would like to follow you on this one, but funds wont allow it just yet.
Old 10-18-2010, 05:18 PM   #8
Paris vvt-i
Thank you all of you! but this 1nzfe made 200whp with a completely stock motor????? I thought Garm had the max safe hp on a stock 1nzfe (182whp)??
Old 10-18-2010, 08:13 PM   #9
No one knows exactly how much power you can push vs. how long the motor will last.
Old 10-18-2010, 09:48 PM   #10
Well. someone figure it out the hard way. Please. LOL
Old 10-18-2010, 10:58 PM   #11
^ I mean someone go beat up on a stock motor until it gives up, so we can all learn.
Old 10-19-2010, 09:08 AM   #12
Paris vvt-i
I am also thinking of changing the transmission to one of a 2nz fe which has longer gear ratios
Old 10-20-2010, 11:28 AM   #13
changchewsoon
Drives: Vios Turbo
double agree on that, hopefully someone can whack the motor until it dies then we all can learn hahahaha....:D
though this guy here has been pushing the stock 1nzfe motor with his turbo kit for more than 3 years, and is an often guest at the local track circuit.
Old 10-21-2010, 03:09 AM   #14
Paris vvt-i
240 whp?? on a stock motor????. by the way what exactly is that water/methanol kit?
Old 11-13-2010, 12:08 PM   #15
Paris vvt-i
do you think that stock 2nzfe transmission will withstand 230hp?
Old 03-24-2011, 01:25 PM   #16
Paris vvt-i
We have almost done with the exhaust and intercooler! photos soon
Old 03-28-2011, 05:26 AM   #17
FunForDummies
FunForDummies's Avatar
Drives: YRS 5dr MT
Looking forward to your next post...
FunForDummies is offline   Reply With Quote
Old 04-04-2011, 07:58 PM   #18
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
don't worry about the transmission, it'll hold the power.
Bolt on turbo kit for our yaris! aucorium Forced Induction Forum 57 02-02-2010 07:50 PM
TURBO KIT for Yaris 1.3 or 1.5 Giupo Items for Sale by private party 27 01-22-2010 11:01 AM
Toyota Yaris I 1.5 Polished K&N Typhoon FAB Items for Sale by private party 2 10-30-2009 03:57 AM
