Old 01-02-2007, 11:18 PM   #1
El Jefe
Drives: 07 yaris s sedan
sirius S50 in my sedan
just finished my s50 install, i absolutly love it and can't stop listening.
and one of the car
hard wired the power under the console with a cigar lighter socket from radioshack, ran the antenna through the right side rocker covers and kick panel, then under the carpet to the console, it's pluged into the aux in that little cubby (stock location) andi had to use a ground loop isolator and adapters from radioshack due to bad ground loop feedback.
all i need now is to find some of the black nylon expendable wire sleeve to cover the wires going to the dock and it's done
El Jefe is offline   Reply With Quote
Old 01-03-2007, 05:44 AM   #2
spkrman
Drives: 1
not bad, sirius is pretty sweet, I've been a subscriber to sirius for over a year now, and had XM for a year before that.
Old 01-03-2007, 06:19 AM   #3
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
I always wanted that sedan red....its hot
Old 01-05-2007, 10:06 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
What did you get from Radio Shack specifically "ground loop isolator and adapters" ? Serious does sell this however I am not sure if that would be the way to go or pick up the same stuff you did:
http://shop.sirius.com/edealinv/serv...dParentID=7872
Old 01-05-2007, 03:50 PM   #5
Bretsuaz
Drives: Yaris sedan
I think the item that you are showing on the Sirius website is used if you dont have an aux input in your car. It seems like the new receivers are much weaker than the old receivers I have had. I believe this is a result of the FCC crap. Therefore, you really need an aux input, and cannot rely on the FM transmitter. This item solves that problem.
I just installed a Stilleto last nite, and I too am getting that horrible whining noise in the speakers from the engine. El Jefe, did the ground loop extender work to eliminate that problem?
Bretsuaz is offline   Reply With Quote
Old 01-06-2007, 05:08 PM   #6
El Jefe
ya it worked perfectly and i didnt lose any sound quality either
Old 01-06-2007, 06:38 PM   #7
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
I had mine mounted in the same spot but didn't like that it crowded my passengers so I slipped it in that side console where the aux plug is. Now it's hidden, so you need to use the remote. But having Sirius rules. I've been a subscriber for 2 years and absolutely love it.
OgDogg is offline   Reply With Quote
Old 01-06-2007, 07:00 PM   #8
Bones
Bones's Avatar
Drives: 07 Yaris S Type
Just wanted to share this mount from ProClip
Bones is offline   Reply With Quote
Why people choose a 5dr Liftback instead of a Sedan?? SimmZ General Yaris / Vitz Discussion 53 05-29-2007 10:28 PM
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 01:19 AM
