![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Switch on the clutch pedal
I have owned a few standards in the past but none have needed as much force to start the car(2007 HB)I really need to push the clutch right into the floor in order to enable the ignition switch.Just wondering if anyone else has found this to be an issue.I will take a look under the dash to locate the switch on the weekend to see if I can somehow adjust it.
The switch on my echo got water in it and froze and the car wouldn't start!
Rep ace the switch or short the wires together in it so you don't have to depress the clutch.
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Squeaky Clutch Pedal? | Kaotic Lazagna | DIY / Maintenance / Service | 43 | 05-29-2016 01:15 PM |
| Clutch safety switch wire description. Kill switch? Add on? | valchrist90731 | DIY / Maintenance / Service | 2 | 08-03-2015 09:04 PM |
| Clutch pedal assembly interference with foot | Connoisseur_of_fine_cars | General Yaris / Vitz Discussion | 4 | 09-23-2011 10:57 AM |
