Old 02-02-2011, 12:13 PM   #1
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
Headlights with thick ice
We had a horrible ice storm yesterday and I didn't get my car in the garage soon enough. Now I have over 1" thick ice and sleet also on my headlights which will keep me from driving in the dark unless I remove it. Can I pour warm water on them to melt the ice or will that crack the headlight covering - are they made of glass or plastic?
It took 2 hours to scrape all the windows this morning but I'm afraid to use a scraper on the headlights. It also won't be melting anytime soon as it will be a low of 7 degrees tonight and not above freezing until the weekend.
DebbyM46227 is offline   Reply With Quote
Old 02-02-2011, 12:17 PM   #2
They are plastic. Scraping is not a great idea, as it will probably result in scratches. Hot water should be fine. Start the car and leave the headlights on on high beam for a while to help loosen the ice from below as well.
Old 02-02-2011, 01:15 PM   #3
SailDesign
Drives: .
Worked well for me this morning, with a quarter-inch of ice.
Old 02-02-2011, 01:45 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
IO find ice melts off on the headlights very quickly
Old 02-02-2011, 02:37 PM   #5
DebbyM46227
Thanks!
Old 02-02-2011, 03:39 PM   #6
RedRide
RedRide's Avatar
Just start the engine, run defrosters and turn on the headlights (if iced up) while cleaning the rest of the car and ice will loosen enough on widows and headlights for easy removal.
I went through this today in NYS.
Old 02-02-2011, 07:57 PM   #7
DebbyM46227
Nope, that didn't work this morning when I had the car running for almost 2 hours while scraping the windows (defroster on). The ice on the headlights was over 1" thick.
I finally got the ice off this afternoon, it took a gallon of very warm water poured over each headlight to get the ice un-thawed enough.
Old 02-02-2011, 07:29 PM   #8
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
YOu could also leave your hi beams on while warming up.. haha
Old 02-02-2011, 08:34 PM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
OH JESUS 1". No wonder
Old 02-02-2011, 08:35 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
.. Cover them over night with something? Wrap a tarp around the front of your car, ride the wheels over it so it won't blow away?
Old 02-03-2011, 02:56 PM   #11
DebbyM46227
It was almost a once-in-a-lifetime ice storm so everything is OK now. And it's going in the garage from now on.
Old 02-04-2011, 09:32 AM   #12
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Maybe I did the wrong thing but it worked
I had the same problem. I gently thumped the lens covers with my gloved fist enough to flex the plastic without breaking it and the ice came right off. I guess I'm lucky I didn't crack the lens cover. Next time I think I'll use the hot water.
rick996 is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
aftermarket headlights be_ha Cosmetic Modifications (Exterior/Interior) 0 10-03-2010 03:06 AM
New headlights CasuaL Cosmetic Modifications (Exterior/Interior) 11 11-24-2009 07:25 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
