Old 01-02-2007, 09:05 PM   #1
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Is this dumb
http://cgi.ebay.com/ebaymotors/15HP-...74908048QQrdZ1
I was kind of intrested and I wanted to know if its a good idea to buy it.
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 01-02-2007, 09:18 PM   #2
acrbill
Drives: Polar White Hatch
What do you think?
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 01-02-2007, 09:32 PM   #3
whoguy
Drives: Yaris YRS Sedan
That looks pretty dumb..... prob a resistor shunt across o2 sensor to cause always rich condition giving noticable increase in power at cost of life of engine.... wot u think?
whoguy is offline   Reply With Quote
Old 01-02-2007, 09:44 PM   #4
KSIbucky
KSIbucky's Avatar
I really doubt because installation looks hard
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 01-02-2007, 09:56 PM   #5
johnnyfive
johnnyfive's Avatar
this is just like the juice box type mods....will trick the engine into running rich...
johnnyfive is offline   Reply With Quote
Old 01-03-2007, 04:00 AM   #6
spkrman
Drives: 1
bunch of BS...
it has been tested, yields a small gain straight off, but the ECU figures out whats goin on and takes it back to stock.
Old 01-03-2007, 06:33 AM   #7
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Forget it!
Old 01-03-2007, 07:46 AM   #8
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Try stay away from little HP cheap mods....
the only cheap legit mod would be the grounding kit. If you buy the specific grounding kit for the yaris, there will be HP gain. Ive read it in some car magazines....
Old 01-03-2007, 06:39 PM   #9
Katana
Katana's Avatar
And you actually feel it!
Old 01-04-2007, 08:38 PM   #10
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
NO! You will get a nominal hp increase when making consecutive dyno pulls, until the car is at optimal temperature. That is all those "magazine" articles are showing. Those grounding kits only remove weight from your wallet and add it to your car.
Biggie™ is offline   Reply With Quote
Old 01-05-2007, 07:47 AM   #11
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
The richer your car runs the less power it makes.
In order to make power you need a LEANER fuel/air mixture, but too lean causes detonation, pre-ignition and overheating.
Regardless what you add to your car to change the F/A ratio the ECU will compensate to maintain the perfect SAFE f/a mixture (stoich)
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 01-05-2007, 09:17 AM   #12
bigsky2
Cousin Vitz
bigsky2's Avatar
True!
But consider the benefit of having a reinforced ground throughout the vehicle; it's very important for those who have lots of electronics and ICE.
Grounding kits are good for reinforcing the ground connection, that's it.
They won't increase HP or performance significantly, if at all.
It's similar to saying a capacitor will allow your sound system to hit harder and your mains will be clearer, that's complete
Old 01-06-2007, 04:55 PM   #13
YarisGuy
Drives: 2006 Yaris
Correcto!
YarisGuy is offline   Reply With Quote
how dumb KSIbucky General Yaris / Vitz Discussion 1 11-14-2006 06:49 PM
Some Dumb Speaker Install Q's =)... BlueLiftback In Car Entertainment + Electronics (audio / video / alarm) 3 10-28-2006 03:24 PM
Help, the wife thinks the Yaris is a Dork mobile.. ElViShGiBbErIsH General Yaris / Vitz Discussion 67 08-25-2006 10:39 AM
Auto vs. Stick in the city Vodalus New YARIS Purchase Forum 30 07-31-2006 10:46 AM
