Drives: Yaris 2009 Join Date: Feb 2011
PLS MY CAR YARIS 2009 FLOOD IN WATER AFTER JEDDAH FLOOD
I CLEANED AND DRY ALL ELCTROICE PARTS . AFTER THAT WHEN I PUT THE KEY TO START THE ENGINE TRYING TO START BUT FAILED .. IF I DISCONNECT THE BATTARY AND PUT THE KEY IN STA RT POSITION AND CONNECT THE BATTARY AT SAME TIME THE ENGINE STARTING BUT IF THE KEY BACK TO NORMAL POSITION THE ENGINE WELL STOP ..PLS HELP ME |
So, if the battery is already connected and you turn the key from ON to START, is does not even attempt to crank, but if you disconnect the battery, place the key is the START position and connect the battery it cranks, but only remains running as long as you keep the key in START?
How high did the water reach?
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
.., the floods in jeddah reached about 1 to 2 feet in some areas.
#4 | |
After that it's the ECM that controls the starting process, so the next thing I would do is to open the ECM case and dry it out or pick up a cheap junkyard ECM to swap in (I've bought Yaris ECMs off ebay for as little as $25).
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: YaRis ka!--Y?2011 Join Date: Jan 2011
your car is not yet old and i believe that the warranty from abullatif jamil will be consider..as long as they include the warranty for ACT OF GOD(aog).i suggest to bring with them and check by the expert mechanic ..because your case is un usual. (lawsamat aksan gib min abdulatiff jamil...akid had fi daman lisa jadida sinaten..(takriban)..mushkila hada matar..swaya fi bahar ..inshallah. .kunlu cun quais......salamalaikom)
#6 | |
![]() ![]() ![]() Drives: yaris y 2010 blue Join Date: Nov 2010
![]() ![]() ![]() ![]() Drives: 2010 Yaris YX Join Date: Jun 2010
Sorry to disappoint you but DAMAGE DUE TO FLOOD is not covered under the limited warranty as per the attached (Page 9). However, it is suggested to contact the dealer for further churvah!
@ waseemsha
سيارتك ليست بعد من العمر وأعتقد أن الضمان من عبد اللطيف جميل وسيتم النظر.. طالما أنها تشمل الضمان لعمل من أعمال GOD.i تشير إلى تحقيق معهم ، والاختيار من قبل خبير ميكانيكي.. لأن قضيتك الامم المتحدة المعتادة. |
salamat sa google translate!
#14 |
#15 |
#16 |
Kaklase ko ng high-school! 2nd year to be exact! Found him sa FB and nageyeball kami when I renewed my passport diyan sa Riyadh! Haus ata nila malapit duon sa Seteen Palace Hotel sa may Malaz! Marami ako kaklas nung highschool diyan sa Riyadh!
#17 |
wahahahhahaha ! ! ! huling huli ni mama zsazsa
| KCALB SIRAY - Photo Scavenger Hunt | KCALB SIRAY | Photo-Video-Media Gallery | 5 | 03-02-2009 10:44 AM |
| LEGATO`` - Photo-Scavenger Hunt | LEGATO`` | Photo-Video-Media Gallery | 1 | 03-02-2009 10:38 AM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
