Old 04-27-2010, 09:14 PM   #1
weaver615
Drives: '07 Yaris 3DRH
Water Pump gone at 33700 Miles
Got home from work tonite and my Yaris was running "weird". It would idle normally, then idle "rough" like it wanted to stall. then i heard the perverbial "swish, swish, swish" and KNEW something bad was wrong. Popped the hood lifted it up and BADA BING, BADA BOOM, I had this pretty pink dryed on substance on the underside of the hood. (see pic), hood.JPG this isnt my cars hood just put here for illustration purposes.
Called the Dealer and I have to bring it in tomorrow to have them look at it. LUCKILY I have a lifetime engine warranty from the dealer and another 2 months on my 90 day dealer warranty, PLUS another 3K miles on Toyota Warranty, so I am HOPING it'll get fixed and not cost me anything. This though is the dealer I was fighting with over the bad tires that were supposed to be changed when I bought the car, so I don't know....I guess I have to wait and see if they are going to tell me I voided the warranty somehow so I have to pay for the repair....wish me luck!
weaver615 is offline   Reply With Quote
Old 04-27-2010, 10:22 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I'm on my 3rd water pump. The last one did the same thing... pink line on the hood. That was at 76,000km I think. I'm now just over 90K. I don't know if it's the bearings or just the seal that goes, but mine wasn't making any noise, just leaving a pink line in the hood.
Old 04-27-2010, 10:26 PM   #3
weaver615
I hope that the third one is a charm (the last one I mean)....Looks like I'd better buy a few of these ahead.
Old 04-27-2010, 10:38 PM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Why do waterpumps in these cars have such a short lifespan?
Enough for a bulletin from Toyota?
Old 04-28-2010, 08:11 AM   #5
Bluevitz-rs
I don't know, but I sure am glad they aren't driven by the timing system like my old Honda is. Because it would be a ROYAL PITA to change it then.
Old 04-28-2010, 11:37 AM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
wasn't there some correlation with people who upgraded pulleys and didn't have the belts tightened to spec having this issue more frequently than fully stock cars?
Trini still hasn't had an issue with his pump.... don't think he touched his pulley at all.
Old 04-27-2010, 11:21 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
mine went out at 19k miles
Old 04-28-2010, 08:50 PM   #8
bronsin
bronsin's Avatar
Short life time for Yaris WPs? My sons ECHO (same engine) has 139k on its WP.
Old 04-28-2010, 10:34 PM   #9
weaver615
Mine is the Stock pulley no modifications at all to the engine save for adding Cruise control...Tomorrow I will find out more.
Old 04-29-2010, 08:29 PM   #10
auxmike
auxmike's Avatar
Keep us posted please.
My wp is at 25k and it's still good, thank God!
Old 04-29-2010, 08:31 PM   #11
auxmike
auxmike's Avatar
BTW, this same thing happened at 16k on my mom's 2006 Corolla....
Dealer replaced it under the extended warr....
It's not just a Yaris thing, it appears.
Old 04-29-2010, 09:16 PM   #12
shinlee
shinlee's Avatar
Drives: 07 liftback
45k miles on the water pump, and 24k miles on the pullies (all 3 NST pullies), and never one single issue.
If you aren't retarded, putting pullies wouldn't affect anything to do with the water pump. But if you are, like, you forget a bolt or don't tighten the belt when done, then yeah... it could happen
shinlee is offline   Reply With Quote
Old 04-29-2010, 10:25 PM   #13
krusty
krusty's Avatar
Drives: 2010 Yaris ce
The dry residue left by the water pump is not from a faulty water pump it has to do with the super long life coolant Toyota uses. It appears that the coolant can cause this condition from time to time and is considered normal.
krusty is offline   Reply With Quote
Old 04-29-2010, 11:07 PM   #14
Bluevitz-rs
So the fact that my overflow was empty and I couldn't see coolant in the rad is considered normal?
Old 04-30-2010, 04:47 AM   #15
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
How come my coolant is green and how does coolant drip upwards to the hood,and with that much leaking coolant there would be a significant puddle under the car after parking a while..
Old 04-30-2010, 07:07 AM   #16
Bluevitz-rs
It only leaks out once the system is hot and under pressure. It comes out of the water pump shaft, and gets sprayed when it hits the spinning pulley.
Old 04-30-2010, 11:05 AM   #17
YarisSedan
Your coolant is green because someone has done a service and used the incorrect coolant. It goes onto the hood cause when the water pump starts to go out it leaks through the weep hole. And as the water pump pulley spins it flings it in a rotational pattern spraying all around it including the hood.
Old 05-01-2010, 01:16 PM   #18
jambo101
jambo101's Avatar
My coolant has been green since the day i bought the car,as for 33k miles on the pump something aint right as My previous Echo went 220,000 and still had the original WP when i sold it,my current Echo has 120,000 with original WP says the previous owner and just turned 60k with no WP issues on the Yaris ,in fact asking around the factory no one who owns a Toyota has ever changed a water pumpcould the shaft be a little bent and be causing premature bearing failure on your particular engine?
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
