![]() ![]() Drives: 01 Toyota Echo Join Date: Oct 2010
coil testing
Anyone know what i can do to check my coils over my plugs? I saw some thing using a test light. I was wondering if there was a tool a garage uses.
I'm familiar with the resistance testing on the high and low side. Do they use a high pot test to measure the high pot resistance? |
The coil packs contain more circuitry than traditional coils, so you can't get at the input side of the coil. You can partially get at the output side, but there is a diode between one leg of it and the +B terminal.
damn it!
| WTB 1NZ-fe Coil Packs (4) | Moses | Willing to Buy by private party | 3 | 01-03-2011 02:22 PM |
| WTB: coil on plug connector | Moses | Willing to Buy by private party | 1 | 12-15-2010 04:29 PM |
| replacing coil springs | yaris9876 | DIY / Maintenance / Service | 2 | 07-11-2010 08:17 PM |
| NST Dyno Testing: BMW 335i N54 CR-Lite Crank Pulley | NonStopTuning | NonStopTuning | 7 | 08-20-2009 04:19 PM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
