![]() Drives: Yaris 2008 Hatchback 5 doors Join Date: Mar 2011
Hi guys, i´m having some issues with the opening and closing doors system i guees, i will explain all the details, well i bought a mvh-8250 pioneer, the 2 din to 1 din kit and the little things that goes one on the left side and the other in the right side, and i bought the wiring kit, first of all i unplugged the original stereo and plug the wiring kit to the original one, and then i follow all the steps that the mvh-8250 brought, after all that i installed everything back and it was everything set up back in place, when i was back at home i realized that the control that it comes with the keys wasn´t working at all and i thought that maybe it was the battery so i decided to buy a new one, i installed it and it wasn´t working either, i took my car to the toyota dealer and the try to see if it was the control and it wasn´t the control was fine, so they told me that when i have time i should leave the car there for a couple of days, so my question is does the new stereo has something to do with the opening and closing sysmtem or ECU? i´m really worried about it! i need some help with it! Sorry if my english is not good enough it has been a long time since i left america! Thank you very much for your time!
One your english is fine brotha, two did you try disconnecting the battery to reset the system if that's not the problem CT Scott will answer your question with no problem and will find the solution 2 your problem, suelte bro
Chances are that you popped a fuse in the process of doing your audio work.
If I had to guess, I would say that it is the 15A DOME fuse in the under hood fuse panel. If that one is not bad, check the following: In the under hood fuse: 7.5A ECU-B In the under dash fuse panel: 25A D/L. 10A ECU-IG, 7.5A ACC.
Big lo thank you dude! i already tried disconnecting the battery but nothing, when i was at the toyota service department they did a test to see if the car was receiving the waves that comes from the control, so the center light in the interior blinked when they pressed the unlock o lock button, that it supposed to mean that the car was receiving the waves but the doors weren't locking or unlocking so they told me to bring the car in a week but i bet they don't even know what is it, so after asking to some friends they told me that it maybe is the ECU that is supposed to be located near by the back door in the pilot side! so i actually don't know what to believe, i found this diagram that i want to share with you and maybe it will help
![]() CTScoot i actually think that i looked all the fuses that you mention, i checked all those fuses under the hood, also i checked all the fuses up where i rest my left foot, i think those are what you meant! am i right? Thank you very much for your help! Last edited by manuel_Ga20; 03-12-2011 at 07:35 PM. |
That diagram is for the transponder key. If that wasn't working you wouldn't be able to start the car.
With the fuses, pull and look closely at the ones that I mentioned (two are under the hood, and the rest are by your left foot). It is not always obvious that they are popped, particularly with the low current ones.
okey tomorrow at mornig i will check all of them and i will let you know! http://www.scribd.com/doc/8679750/20...l-36-Door-Lock check this part of the manual this is what they showed me, page DL-64, with my key control the center light blinked twice, and with another key blinked once but longer. So they told me the receiver is fine!. Thank you for your help!
#7 | |
Still check the others, since the door control receiver just passes data over LIN BUS to the Body ECU. The body ECU then does the actual work of locking and unlocking the doors. The other fuses relate to that function.
I think that tomorrow all will be in order, thanks to CT
CTScott i checked all the fuses and it seems to be that alot of them are not working tomorrow i will change them, i even saw something really weird on the fuse number 26 that it says id/up/mir htr and its that the plastic is kind of weird as you can see on the picture!, i took it out and i put my tester were the fuse should be and it seems that this slot is like no working, i'm really worried about it, the only modification that i did to the car was the new Stereo so i don't get it, does the stereo has something to do with the ECU? here is the picture: [img=http://www.freeimagehosting.net/uploads/th.f79418b110.jpg]
#10 | |
you mean the main body ecu? where can i get one of those big fuses? are they easy to find? thank you bro for the help
Correct. I am not sure about down your way, but up here, auto parts stores carry those larger fuses.
These are the fuses that are not working: 1,2,3,4,5,6,7,16,17,18,20,21,26,30,31! I'm gong to try to get the 30A DEF i dont know how to test it so i'm just going to get one of them! Do you think that if i change that one will solve my problem? Thank you!
#14 |
That 30A fuse doesn't drive the feed to all of those, so I don't think that that fuse is the issue. In the picture I posted above look at the connector above the center relay labeled 4G. See if that connector is actually plugged in. It is a white connector with one very large diameter wire.
#15 |
Yes that is conected right! So and my car is working properly the only thing thati thinkis not working is the locking doors and unlocking with the wireless control!
#16 |
OK. How are you testing for power at the fuses?
#17 |
I got a tester that i connect to the chassis and i see if the light turns on in the tester!
#18 |
OK. Check for power on that big wire in position 4G. That should have power even with the ignition off.
| Tags |
| door, ecu, ecu wiring, stereo, wiring |
| Car doors are not self-locking when left unlocked | fainty_girl | General Yaris / Vitz Discussion | 27 | 03-14-2011 09:12 AM |
| lambo doors.. @@ ?? why not !!! | S69 | Cosmetic Modifications (Exterior/Interior) | 11 | 04-11-2007 05:14 PM |
| Speaker grills / holes on the doors. | IsLNdbOi | Wash, Wax, Detailing, Exterior Repairs | 3 | 09-15-2006 10:28 AM |
| do u think a coilover from tein (3 doors) will work with sedan ( 4 doors) | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-21-2006 04:59 AM |
