Old 01-08-2007, 12:41 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Engine upgrades
HI Guys
Im planning some engine upgrades soon , eg , camms , gas flow , throttle bodies and a de Cat exhaust , and a ECU upgrade , maby bigger injectors..any advice on the yaris 1.3 engine mods?
i think i should get around 100 KW.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 01-08-2007, 09:53 AM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Sorry dude, but you won't find much info about the 1.3L engine on this forum. 99% of the guys drive the 1.5L USDM USDM engine.
Old 01-08-2007, 12:18 PM   #3
graywolf_14
Drives: um not a yaris but hopefully
And for the 1.5 here in the us atleast there is I think header,cai,exhuast and that is about it. But I dont really look around on the net so I cant tell u for sure.
graywolf_14 is offline   Reply With Quote
Old 01-09-2007, 12:27 AM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
im going to one of the local top tuners next week , and get a custom throttle body made up , see if i can get my ECU remapped , and also find out about degreeing my cams and flowing the head.Will let you guys know what they say.And i also wanna put my car on the Dyno to see what see's doing.
JDMtuner
www.jdmtuner.co.za
Old 01-09-2007, 09:44 AM   #5
firefly1_0
What the...?
firefly1_0's Avatar
Drives: '06 Blazing Blue 3 door RS.
Um, your TB is a Drive by wire that is servo controlled, meaning that your TPS sensor is under your gas pedal and the ECU is actuating the TB. unless all you are doing is putting a bigger one on from another toyota, you should re-think this...
my other car is still faster...
...and the engine is way smaller.
silly ricer, useless wings are for penguins...
firefly1_0 is offline   Reply With Quote
Old 01-10-2007, 04:34 AM   #6
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
what u mean? are you talking about the pressure sensor?
I took my yaris to a dealership to have the ECU and engine checked out , all seemed ok , although all they check for is errors, and if none , then to them , everything is ok , the only thing they could do was turn my warning buzzer off for the seatbelt.
one thing they showed me is that as a factory default , the throttle or gas pedal , is set to a maximum of 81.1 % , wierd hey?almost detuned.
JDMtuner
www.jdmtuner.co.za
Old 01-10-2007, 04:46 AM   #7
spkrman
Drives: 1
so WOT isn't WOT?
Old 01-10-2007, 05:03 AM   #8
interesting....... In this case a larger throttle may be useful... Or an ECU tweak, somehow?
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 06:20 PM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
Engine Working too hard? David81 General Yaris / Vitz Discussion 8 06-14-2006 11:17 AM
Noisy Engine David81 New YARIS Purchase Forum 8 06-02-2006 12:15 PM
