![]() ![]() Drives: 01 Toyota Echo Join Date: Oct 2010
Brief start up squeel
Hello Everyone,
I changed my belt about 600 miles ago. I made sure it was tight and after about 30 miles i hit it with a little belt dressing. Everything has been fine but on two occasions when it was cold. The car started and squealed for a few seconds then it would stop. I looked at the belt and it looks like your average belt, a little bit of a sheen on the top. When I changed the belt the deflection in the center was probably a half inch. The deflection appears to be about te same. Could it be the weather? It happened only twice now but made the car seem ghetto. I rechecked the deflection and its a tad over 1/2" in the middle. The deflection really hasn't changed from what i remember. Anyone have idea what it is or should I just go and re tighten everything. The squeel was only 2 seconds, not rev dependent and it happened 1-2seconds after start up. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
It's just the cold.
Its a bando belt that I put on, so its not a crap belt.
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
could be due to the cold and maybe one of ur pullies being stiff. check again and makesure its tight enough.
![]() Drives: 2007 Polar White Sedan Join Date: Jan 2009
I had the same issue when the weather here got below freezing. Would squeal momentarily every time I started it up. Now that things have warmed up again everything is fine. I took it by the Toyota dealer in town just to have everything double checked and they agreed with me that it was just the cold and that there was nothing to worry about.
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Plenty cold here and mine, the OEM original at ~88,000 kilometers, has never made a peep although the valve-train is ticking a bit on cold starts lately. Likely needs a maintenance adjustment.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
There's nothing to adjust in the valve train... well there is, but nothing you NEED to adjust. It's normal. Just keep changing the oil like normal and you'll get a lifetime out of it.
![]() ![]() Drives: 2010 Meteorite Liftback Join Date: Nov 2010
belt will squeal if too loose OR too tight... adjust it slightly in both directions, first loosen it a bit, then tighten it a bit after that if it doesn't get better.
on my Jeep I manually adjust it and 2 winters ago I had it too tight and it would squeal like crazy in the morning, I just loosened it up a tad and it hasn't made ANY noise. also, don't use that belt dressing stuff, its garbage, thats meant to help extend belts life that are way past their prime and should be replaced anyway |
toyota
try adjusting first if not try belt spray..
ive always been told to stay away from belt spray
| push start vs electric start? | yaris2010RS | General Yaris / Vitz Discussion | 18 | 04-07-2010 03:20 PM |
| Car wont start - help! | tamo300 | General Yaris / Vitz Discussion | 14 | 03-23-2010 11:44 PM |
| Yaris does not start | jake002 | DIY / Maintenance / Service | 21 | 01-05-2010 09:53 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 08:11 PM |
| Viper Remote Start | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-13-2008 06:06 AM |
