GRO H2O
Drives: Yaris Join Date: Apr 2011
Super quiet exhaust.
Looking for after market exhaust that is as quiet as the stock exhaust. No fart actions. Any suggestions?
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
the TRD jdm version s muffler i have is QUIET and looks stock without the big gaudy tip....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
"As quiet" means just as restrictive. Even the TRD axle-back is a little louder than stock.
What is your reason for wanting an aftermarket exhaust?
GRO H2O
Free up the flow and maybe gain a tiny bit of power. I'll slowly keep on adding performance tid bits over the next year. If I can get 15hp more I'm good but don't want to sound like a wanna be race car.
While I agree with this statement, some aftermarket exhausts do get closer to others as far as volume levels. I've read that the Fujitsubo Wagolis is a good example of the quieter sort... also listened to a couple of youtubes.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
any aftermarket exhaust will be louder. if you go custom with magnaflow muffler it should be quiet until about 3 grand on the tach and then start getting louder....but it's not loud. it's a nice low sound. it will resonate, but i dont have that exhaust yet so i cant tell you it's resonant rpm range.
http://www.magnaflow.com/02product/streetmufflers.asp 14807 for round tips and 14833 for square tips. these are the mufflers i'll be using with a custom catback pipe. removing the resonator will make it louder, and also a header will make it loud. keep the resonator and go axle back for a quiet exhaust, but it's got more restrictions. |
I need more stars
Drives: Liftback Join Date: Jun 2009
Nothing is as quiet as the stock exhaust (echo)
i'd have to suggest the muffler i have: Dynomax Super Turbo muffler. If you plan on keeping your cats, then this thing would be perfect.
CLIFF
i agree with peter! i am running a dynomax 2" cat-back with 2 1/2" tip looks stock and not to loud. also running a meagan header!
"who the cap fit let them wear it"
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
CLIFF
its a universal muffler, so u need to have the shop bend the 2" pipe cat back and do some manuvering of muffler to fit. but i got it to work. actually my muffler is a 2 1/4" in n out. the guy a muffler shop told me that 2 1/4" was to big lossing too much backpressure. i say if u want a lil better flow get a bigger than stock universal replacement muffler with piping!!
#12 | ||
#13 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
You could mimick the stock multi-pass set up by using two or three high performance mufflers. I'm not sure how many mufflers you can cram in the stock location, but going through three large diameter turbo mufflers might be pretty quiet. Rearward through the first, forward through the second, rearward through the third. |
#14 |
I ain't even mad
Even the TRD Exhaust system is loud.
#15 |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
I am looking for something similar, but I want it to be just a hair louder than stock. I had a random turbo muffler on a civic and liked the way it sounded, just the slightest bit of increase in sound and no resonance...I'm just not sure it will be exactly the same on the Yaris so i haven't pulled the trigger.
#16 |
![]() ![]() ![]() Drives: 2010 Yaris Bayou Blue 3DR Lift Join Date: Sep 2010
I love my Tanabe Touring Medalion. Just the right amount of pep when I'm accelerating and stays nice and quiet when I'm not.
#17 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
+1. Good sounding exhaust without being too loud with a nice, deep tone. Built like a brick outhouse, too.
#18 | |
| Quiet Aftermarket Exhaust?? | darkMINI | Performance Modifications | 30 | 01-21-2011 10:26 AM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| GReddy prototype = Free Exhaust! | Chris_Lum | California | 30 | 02-27-2007 10:13 PM |
| anyone use Dynamat/ Be Quiet to deaden exhaust noise? | Galavoxx | Performance Modifications | 9 | 11-29-2006 04:28 AM |
