Old 09-05-2007, 09:33 PM   #1
vacantj
Drives: Yaris 4Dr sedan
205/45/17 or 205/40/17 Front & 215/40/17 Rear
I have a 4 door sedan and I got 17" wheels (38 offset) - I have Tanabe NF210 Front: 1.2" & Rear: 1.6" springs installed.
I'm going with Maxxis MA-Z1 Victra tires:
http://www.maxxis.com/products/autom...il.asp?id=5456
I'm trying to figure out which size of tires to go with:
205/45R17 all around
or
205/40R17 Front, 215/40R17 Rear - (Black Yaris suggested this setup will give better corning)
Any suggestions?
vacantj is offline   Reply With Quote
Old 09-05-2007, 09:45 PM   #2
oscar845
Drives: yaris rs HB 06
I have tanabe df 210 on my yaris HB and 17'' mags with 205/40zr17 all around and that is fantastic but it s not a sedan.
oscar845 is offline   Reply With Quote
Old 09-05-2007, 10:19 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
With ET38 and NF210, you could go with 205/40's all 'round OR 205/40's up front and 215/40's rear.
I've seen this "staggered" set-up in Japan, and it looks great and works well. The difference in tire sizes front to rear is not really visually apparent, but it does compensate some for the difference in tuck front to rear, so it looks neat, even, and tight.
Old 09-06-2007, 12:45 AM   #4
Lafiro
Drives: 06 Yaris Sedan
I was going to do 215/45/17...... is this too big of a tire for the rim?
Old 09-06-2007, 09:07 AM   #5
kimona
kimona's Avatar
No, this size is not too big for the rim and will work well if you have the proper offset.
So, what is your offset and are you lowered or planning to lower?
Old 09-06-2007, 10:49 AM   #6
Lafiro
I am lowered with TRD springs, and my rims are currently a +42 offset.
Old 09-06-2007, 01:23 PM   #7
kimona
kimona's Avatar
You should be okay with TRD's and ET42.
What size tires are you running now, and how are you up front? With 205's and ET42 you should be slightly tucked by a few mm's up front? Can you confirm this?
Old 09-06-2007, 08:22 PM   #8
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
If you run the wider tire in the front and the narrower one in the rear it will improve cornering. Running more rubber in the rear on a FWD car will promote understeer, something most people try to overcome by using big rear anti-roll bars.
Personally, I'd run the same size wheel and tire front and rear on a Yaris. That way you can easily rotate the tires to increase longevity.
Biggie™ is offline   Reply With Quote
Old 09-06-2007, 08:56 PM   #9
kimona
kimona's Avatar
If you're going for best fit and looks (and drive within the limits), then running 10mm's more rubber in the rear won't make any noticeable handling difference whatsoever in everyday driving conditions.
If you plan to race with your everyday tires then take into consideration an application that works best.
If you're a fan of tire rotation (which I am not) then staggering tire sizes will prohibit rotation and decrease tire longevity some.
I've seen dozen of Vitz in Japan with staggered offsets (very common application), and many with staggered tire sizes. In Japan its all about the perfect fit. For those who race their cars, they almost never use their steet wheels/tires.
Old 09-08-2007, 02:22 AM   #10
Biggie™
Biggie™'s Avatar
Thanks for repeating what I said... If you enjoy replacing the front tires 400% more often than the rears, I think you probably shouldn't drive an echno box.
Old 09-08-2007, 11:12 AM   #11
kimona
kimona's Avatar
Well... 400% is probably quite an exaggeration, but true the fronts will probably be about 75% worn and due for a change, while the rears will probably still have about 75 tread left.
I don't see anything wrong with that.. just change the 2 front tires... later change the 2 rear tires.
As long as you maintain your car... keep the tires inflated properly and the wheels aligned regularly, then it really doesn't cost more if you don't rotate.
Old 09-08-2007, 05:03 PM   #12
Biggie™
Biggie™'s Avatar
So 300% is an acceptable estimate, yet 400% is quite an exaggeration?
Old 09-07-2007, 04:02 PM   #13
x2
Old 09-06-2007, 08:40 PM   #14
vacantj
do you guys think I can go with 215/45R17 all around?
Old 09-06-2007, 09:45 PM   #15
SDsurfrider
SDsurfrider's Avatar
Drives: 07 Sedan S
http://www.miata.net/garage/tirecalc.html
I try and stay under 1% difference than was designed for the car
another tool:
http://www.1010tires.com/TireSizeCal...?action=submit
SDsurfrider is offline   Reply With Quote
Old 09-06-2007, 11:51 PM   #16
kimona
kimona's Avatar
Manufacturer recommendations are generally within approximately 3% of OEM.
These are the Yaris OEM tire sizes:
175/65/14 = 23"
185/60/15 = 23.7"
195/50/16 = 23.7" (Here in the States, we commonly run 205/50/16's @ 24.1" because that's a more readily available tire size)
205/45/17 = 24.3
The difference between 14" OEM and 17" OEM is already 5.5%!
As far as I know (provided there is sufficient clearance) you can "safely" vary from each OEM size listed above by approx. 3%.
In Japan, I've seen Vitz (unlowered) with 205/50/17's. That's presumably within the 3% limit. It looked good, filled in the wheel gap nicely, and apparently performed well enough on the street.
Old 09-07-2007, 12:26 AM   #17
Lafiro
Actually, Im with 205/40/17 right now, the front is flush/looks good, but the back looks like its far in on both sides, so for future tires, Im planning on getting 215/45/17 to have a wider tire for more grip + higher profile for a more comfortable ride. Not only that, if I add Spacers in the back, the whole thing will look flush.
Also ther is a big difference in performace/comfort between 40 and 45 profile tires if you do the research.
Old 09-07-2007, 02:11 AM   #18
03Z33
03Z33's Avatar
Drives: TCR10
I ran 215/45/17 Falken 615's (which run wide) on 17x7 +38 wheels when I had my Tanabe DF210 springs and had no rubbing.
I still have these wheels and tires but I don't run them too often since my car is too low now with the coilovers, I'll probably need to go back down to a 205/40/17 to make them fit due to the taller diameter with the 45 series.
With just springs it worked well though since it helps fill up the tire gap, I would do it again if you're not planning to dump the car on coilovers.
Is worth it to replace only front and rear speakers? tealio In Car Entertainment + Electronics (audio / video / alarm) 35 04-16-2010 09:11 PM
Thailand OEM/Aftermarket Accessories and Bodykits GB Round 2! eTiMaGo Items for Sale by private party 118 09-10-2007 02:10 PM
