Old 08-09-2011, 10:29 AM   #1
Shawn D
Drives: 07' Yaris Hatch
Will these fit?
Hey does anyone know if the 14" Honda HX wheels will fit on our cars without issues. I would assume they would but Just thought I'd ask to see if anyone is already running them.
Shawn D is offline   Reply With Quote
Old 08-09-2011, 11:06 PM   #2
will depend on spoke design and offset....have some pics?
Old 08-10-2011, 12:12 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
I presume this is the Honda wheel you're talking about. I don't recall seeing any yarisworld member with these wheels. Unless someone can give you a definitive answer, I guess you'll just have to test fit.
Old 08-10-2011, 04:16 AM   #4
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Had these on my old civic. They are 4x100 and about 45 offset. Should fit on the yaris..
weedtank is offline   Reply With Quote
Old 08-10-2011, 07:42 AM   #5
kimona
kimona's Avatar
The bolt pattern and offset are fine, but with some 13's and 14's there may be an issue with brake caliper clearance.
Old 08-10-2011, 11:48 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
What about the hub ring diameter? Isn't that part of the load bearing?
Old 08-10-2011, 11:55 AM   #7
So long as the hub bore of the wheel matches or exceeds the Yaris hub diameter (which these wheels do), OP is fine. Just like any other aftermarket wheel, hub rings will be required to fill the gap.
I believe these wheels are manfactured by Enkei, and I've not heard of any issue with 14" Enkei wheels to clearing the calipers. This does however remain as the one and only potential fitment issue.
Old 08-10-2011, 10:08 AM   #8
33OH
Drives: '08 Yaris
May have to run small (5mm) spacers, but I'd say there's a very good possibility they'll fit.
I ran 14" CRX SI wheels with 5mm spacers and they cleared.
Old 08-10-2011, 12:06 PM   #9
The 4x100 Hondas are 56.1mm for the center bore (same as Mini Cooper) versus the 54.1mm for the Yaris. It is really hard to find hubcentric rings for that small of a difference, but with the proper tapered lug nuts you can run lugcentric.
This is a great reference for bore and lug pattern:
http://adaptitusa.com/referencebook.htm
And, this is the only place where I have seen off the shelf 54.1 to 56.1 hubcentric rings:
http://www.hubcentric-rings.com/size-56.1-54.1/
Old 08-11-2011, 10:39 PM   #10
at a 45 offset...id wager you'll need 5mm spacers to clear the calipers
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 07:48 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
