Old 08-17-2011, 08:55 PM   #1
bambam28
Drives: Yaris Hatchback 2012 SE
A/C PROBLEM
Hi guys I buyed a yaris HB 2008 last week with 29000 miles on it, I noticed that after driving like 30 to 40 minutes the a/c stops blowing cold air and blow cool air. I have to turn it off and wait like 5 minutes and then it starts to work again...anybody know what it could be?
thanx
bambam28 is offline   Reply With Quote
Old 08-20-2011, 11:25 PM   #2
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Sounds to me like you are a little low on Freon. Small can from an auto parts store would do fine for you. it is not hard if you get the one with a gauge with it... just fill till the upper part of the green and do not go into the red zone. It'll work all good again.
bobolinko is offline   Reply With Quote
Old 08-21-2011, 08:55 AM   #3
ciscobear
Drives: Toyota Belta
Sounds like one of your lines are icing up, had a similar situation with suzuki van. When I checked, the line was iced up then I would turn off AC. Once the ice melted from the heat, AC would be good again.
ciscobear is offline   Reply With Quote
Old 08-21-2011, 09:35 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It's possible the condenser is icing up after long use. Are you blasting it at full speed for 30-40 min? There also might be a clog in the drain line.
Old 08-21-2011, 10:17 AM   #5
This would be my thought as well. The AC ECU detects the pressure of the freon and if it is too high or too low it will shut down the compressor to avoid damaging it.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
A/C sometimes won't start? Greedo51 DIY / Maintenance / Service 5 07-23-2016 08:50 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
