Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 10-30-2011, 08:32 AM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
RPM to Speed Ratio
Mga kayaris, tama ba or same ba sa inyo na running at approx 140-150kmh eh nasa 4000rpm natin medyo mataas at galit na galit engine right ganito rin ba sa inyo???
I've had a different experience kasi sa Expedition Ford ng office which goes to about 180kmh at 3200rpm or 3500rpm which could make sense dahil sa diperensya ng engine type and number of cylinders pero ganito rin ba Yaris ninyo 140-150kmh at 4000rpm na??
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 10-30-2011, 02:52 PM   #2
syntax
syntax's Avatar
yep that's about right we have a 4 cylinder 1.3L engine, but pwede pa bumaba ang rpm kung bago sparkplugs and kaka injector clean mo lang...
Old 10-30-2011, 03:28 PM   #3
charlieXX
Corporate Slave
charlieXX's Avatar
@ syntax, my Yaris has clocked about 38K so medyo ok pa spark plugs yung injector cleaner magkatalo saka anong octane gamit ninyo 91 or 95? naka 91 kasi ako?
Old 10-31-2011, 02:46 AM   #4
syntax
syntax's Avatar
@ charlie, medyo ok pa nga ang spark plugs mo pero malapit na palitan yan, octane rating? well medyo malalim na katanungan yan at maraming kuro kuro tungkol sa octane rating, sa akin at maybe sa ibang kayaris, we follow the manufacturer recommendations which is 91, kapag binuksan mo rin takip para sa fuel tank mo, makikita morin dun 91... hth
Old 10-31-2011, 04:36 AM   #5
charlieXX
Corporate Slave
charlieXX's Avatar
@ syntax, yeah that's what I follow as well and a reco of a friend in Toyota na rin na our engines are a bit on the small side and that the 95 is going to be too hot for it.
Old 10-31-2011, 04:36 AM   #6
charlieXX
Corporate Slave
charlieXX's Avatar
Q: naka iridium na ba itong Yaris natin from the production line?
Old 10-31-2011, 04:53 AM   #7
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
as far as my 2008 yaris is concern, hindi sya naka iridium..
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 10-31-2011, 05:27 AM   #8
syntax
syntax's Avatar
nope, OEM denso plugs lang
Old 10-31-2011, 06:05 AM   #9
charlieXX
Corporate Slave
charlieXX's Avatar
Does anybody here have an iridium plug, para masilip muna ang performance upgrade bago magpapalit ng iridium
Old 10-31-2011, 06:15 AM   #10
duke_afterdeath
tol merong naka iridium d2 and according to him mas ok ang response.. sad to say ndi na sya active sa site...
Old 10-31-2011, 06:52 AM   #11
charlieXX
Corporate Slave
charlieXX's Avatar
hmmm sounds like a fun project to ponder on.
Old 10-31-2011, 06:52 AM   #12
rickyml
rickyml's Avatar
Drives: Yaris 2008
ako at si yaross naka iridium na... ayos ang response nya as in 1click pagnagstart at may kaunting pagbabago sa hatak.
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 10-31-2011, 06:55 AM   #13
charlieXX
Corporate Slave
charlieXX's Avatar
@ricky how much each ng iridium, and do you still have it serviced at toyota wala bang problema pagka casa pa rin ang service then naka iridium spark plugs ka
Old 10-31-2011, 06:58 AM   #14
syntax
syntax's Avatar
Old 10-31-2011, 07:01 AM   #15
duke_afterdeath
tol ricky, naka iridium na pala kau, nahuhuli ako sa balita
@charlieXX, I think 40-50 SR. each ang price.. am I right tol ricky?
Old 11-01-2011, 02:13 AM   #16
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Tol nung nagpalit ako ng spark plugs, NGK yung nakita kong nakalagay tapos Denso na yung pinalit ko.. no fulus yet for iridium plugs.
rye7jen is offline   Reply With Quote
Old 11-01-2011, 02:35 AM   #17
syntax
syntax's Avatar
nye malish NGK pala ung nakalagay.. nagpalit ka na ng sparkplugs rye?
Old 11-01-2011, 02:50 AM   #18
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Oo tol, mejo may katok minsan sa starting eh, tapos mag-2 years na rin mga plugs ko kaya pinalitan ko na, si gian na tumira. Try ko picturan yung old spark plugs, mejo malayo na nga ang gap dun sa lead ba yun? ngaun parang bago ulit yung response ng engine. kung mapapansin niyo nung bagong kuha niyo ang yaris niyo, pagpasok ng primera tapos clutch papuntang segunda eh parang nahuhuli yung clutch natin? ewan ko mahirap explain, pero parang ganun yung feeling ulit nung napalitan na ng bagong SP. nilinisan na rin namin ni gian yung throttle kasi bumaba ng 400RPM ang idle, ngayon back to normal na ulit..
RPM at 60 mph 5 speed manual mark schofield DIY / Maintenance / Service 13 10-08-2011 12:14 AM
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
