WILL IT RUB ???
??? will it Rub ???? 18x7.5 et 40 tire 205/40/18 yaris sedan dropped on df210 stock shocks, please help and if u have pics please post
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
I had 18x7.5 42et with a 205 35 18 tire lowered on DF's and on stock shocks/struts and they rubbed on full lock turns and on my commute when there was a major dips or bumps mainly going downhill, overall they rubbed less then expected and the rubbing was upfront on the plastic fender liner.
#3 | |
Start another Oil Thread!
camber is your friend.
you nailed it sir.
anyone running this set up ????
NO RUB!!!
Put 2 people in the back, take it over some railroad tracks, then report back. Otherwise, looks good just sitting there.
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Mine rub up front. Never out back, even loaded to the max.
Less rub now with the OEM -1.5 degree camber set-up. But the will still touch while high speed cornering and hitting dips. Seldom even now while running straight over swales or dips. Winter boots on now so never a touch, but no dry traction either.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Need new shoes. Will this rub? | psykobowler | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-02-2010 12:33 AM |
| Help! Tein S-tech with 195/55/15 will it rub?? | evo165 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 08-21-2009 10:59 PM |
| Aftermarket exhaust systems that do not rub on the road! | fuji | Performance Modifications | 10 | 04-28-2009 07:22 AM |
| Does +43mm rub? | Split | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 02-28-2009 08:39 PM |
| want 2 lower with tein but have tyre rub HELP! | MR. CANTON | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-24-2007 05:16 PM |
