keckbot
Drives: 2007 Blazin' Blue Liftback Join Date: Aug 2011
Do I Need to Replace Water Pump?
Been having some pink crusty crud showing up on the underside of the passenger side hood and it is coming from the hose connection circled in the second photo. I found some similar posts on here stating that this means I should replace the water pump. I bought a new one and just want to verify that this is what i need to do. I have 80,000 miles on my car and this is the original pump. Any assistance is appreciated. Thank you in advance.
| Has anyone had their Water Pump replaced? | Carrot Top | DIY / Maintenance / Service | 48 | 03-20-2017 01:32 AM |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| Water Pump gave up on me finally | Vioz | DIY / Maintenance / Service | 4 | 07-31-2011 06:08 PM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| HELP: changing water pump | dlplunkett44 | DIY / Maintenance / Service | 4 | 02-06-2011 09:26 AM |
