Old 02-23-2012, 07:55 PM   #1
mark293
Drives: 2007 THREE DOOR 5 SPEED
My Oil Analysis 2007 hb 5 speed 123,994 miles
2007 Yaris 5 speed, HB purchased at the peak of the gas crisis in 2008 with 22k miles. I just had my first oil analysis and I am pleased with the results, but first a little history.
Vehicle mileage upon oil analysis 123,994.
74 mile per day roundtrip commute (all highway)
Original brake pads, front and rear.
Mobil 1 5-20
NAPA platinum oil filter
Plugs at 60 and 120k
Air filter every 15k
10k mile oil change interval
Militec-1 metal conditioner treatment every other oil change
5k mile oil filter change interval
SS250 oil filter magnet by Filtermag
EBay magnetic drain plug filter
Royal Purple manual transmission fluid
Hankook Optimo 100k mile tires
Blackstone Labs states: You are doing all the right things in regards to this engine, and based on the remarkably low wear numbers we found in your engines first sample, we'd have to say your engine is replying favorably to all your care. Universal averages show how metals typically look from this engine type after about 6000 miles on the oil. Your oil run was nearly as long, though metals read quite a bit lower than average. No fuel, water, coolant or other excessive problematic was found. Try 7000 miles next. Nice!
Aluminum 3 3
Chromium 0 0
Iron 5 9
Copper 0 2
Lead 0 1
Tin 0 1
Molybdenum 66 84
Nickel 0 0
Maganese 0 0
Silver 0 0
Titanium 0 1
Potassium 4 3
Boron 41 12
Silicon 20 15
Sodium 3 22
Calcium 965 2424
Magnesium 724 87
Phosphorus 650 823
Zinc 695 861
SUS Viscosity @ 210 degrees F – 48 48-57
cSt Viscosity @100 C 6.67 6.7-9.7
flashpoint in F 395 >355
Fuel % <0.05 <2.0
Antifreeze 0 0
Water 0 0
Insolubles .2 <.6
Not sure what all that means, I just know I get 400 gallons on every tank. Those with a greater knowledge of oil analysis, please chime in.
**Sorry I couldnt scan the doc at home. My printer/scanner is acting up. Ill try to post the complete doc tomorrow when I get to work.
mark293 is offline   Reply With Quote
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
2007 Blitz Supercharged Yaris LB 5 speed jdmekcivic Cars for Sale by private party 71 05-23-2010 08:58 PM
2007 Yaris 2dr HB Stick (manual) 20K miles Nor Cal for $9600 arihant Cars for Sale by private party 0 05-06-2009 01:04 AM
