91octane $2.24nzd / litre
Drives: 05 5d 1.3 CVT Join Date: Jul 2009
2SZ-FE TSB's ??
I recently found these whilst doing a search online.
Not too sure what they are, perhaps TSB’s? I’d like to know a little more on the ones below if anyone help? not registered for the site and made the assumption one must be in the game to be able to do so and since I've never come across a list like this I thought I'd share the link too. 2SZ-FE Squeaking noise from gasket, exhaust pipe -04/01/2007 2SZ-FE Engine- water pump leakage/blocked -25/02/2010 2SZ-FE Engine oil leakage via the flywheel bolts -30/10/2009 2SZ-FE Engine ticking noise caused by excessive valve clearance 30/10/2009 Source: http://www.toyota-tech.eu/TsbResult....1-3674AE9B76FB Sorry mods if I've put this in the wrong place, wasn't sure if it should go in the TSB's or not. welcome to move and sorry if I was wrong. Last edited by Mikeey01nzl; 03-13-2012 at 06:07 AM. |
Those are the equivalent to TSBs for the European Yaris.
Thanks CTScott, do you know any more info on about the ones i've mentioned?
No, but you can subscribe to the European site in hour increments if you want to take a peek at them.
| Compilation of Yaris TSBs | eTiMaGo | DIY / Maintenance / Service | 72 | 07-04-2024 10:36 AM |
| Question on TSB'S | nimith | DIY / Maintenance / Service | 0 | 07-07-2009 09:08 PM |
| TSBs for 08 models | moden1223 | DIY / Maintenance / Service | 0 | 04-10-2009 05:28 PM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
