Old 04-11-2012, 07:36 PM   #1
746watts
Drives: 2014 yaris hybrid
Question Disconnecting rear hub ABS
I've ordered a replacement wheel bearing hub (making humming noise after 202,000kms), I've had a look at what i have to do and clean off road dirt, but the ABS connector won't come off and I afraid to apply too much force and break the connector.
I got the first part of the connector undone, the flap which unclips on the sides and then pivots away 90 degrees. It's the next (and last I think) part that is not moving, I felt with my thumb and finger for a release tab to squeeze and pull at the same time and the connector should come away, but it's not. I've sprayed WD40 onto it to soak. Am I missing something? How does the ABS connector come off? I hope it's not corroded on. I searched for abs info but found no threads describing the connector removal.
Any advice is much appreciated.
746watts is offline   Reply With Quote
Rear hub spacers Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-01-2010 11:54 AM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
