![]() Drives: 2008 Yaris Sedan (Auto) Join Date: Jan 2010
Hello Everyone,
I would appreciate some input into this situation. I have a 2008 Yaris Sedan, in optimum condition treated like a baby and always using Shell and cleaning fuel injectors every 15000KMS with Seafoam. Tire are always properly inflated and driving is mix of highway and city from Delta to Burnaby BC about 48 kilometres round trip to and from work. I used to get 650+ Kilometres per tank before, however lately its around 500 or even 440 and this has been an ongoing problem well through Summer. Any thoughts? |
Congratulations. You are now getting what I have always gotten.
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Slow down.
And stop using Sea Foam! That shit destroys rubber seals!!! |
#4 | |
![]() ![]() Drives: 2011 yaris rs Join Date: Nov 2010
I also lost my awesome MPG on the old Echo I had. A few things for me were.
Underinflated tires, worn spark plugs, and rotors that were dragging a bit due to moisture in the brake fluid(the pistons? weren't retreating properly). Also just due to higher mileage on the engine. You're getting phenomenal MPGs by the way. Wish I was getting even close to that in the city. I get about 420 klicks per tank in the city (36 MPG) Quote:
![]() Drives: Blue 5 door hatchback Yaris Join Date: Apr 2011
When is the last time you changed the oil?
Also I would do more research about this Sea Foam stuff. |
![]() Drives: 2011 3dr hatch Join Date: May 2011
O2 sensor?
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Winter gas, or do you have that year-round up in Canada?!?
Drives: 2007 Yaris Join Date: Dec 2011
I get 27mpg in my Yaris, and about half of those miles are highway.
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
will EFI cleaning help? or fuel injector something like that?
#10 | |
![]() ![]() Drives: 2010 4D Sedan 5M w/convenience Join Date: Apr 2011
To OP,
Did you ever find out what was going on with your MPGs? |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
I noticed a big drop in mpg when i changed the original tires on my 08 sedan.maybe a 15% difference, also i think the gas companies change their gas formulas for winter that also adds to a decrease in mpg
Have Yaris will travel.. |
![]() Drives: 09 3dr HB 5sp Join Date: Apr 2011
running the heat in defroster mode alot ?
#14 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Perhaps the MAF sensor needs cleaning?
#15 |
Notice a lack of power or anything like that? Maybe a piece of the catalyst has broken and is clogging the exhaust route?
#16 |
any update yet? I had same problem and seemed to have fixed it ... peprhaps.
#17 |
![]() Drives: 2007 Yaris LE 5 dr LB Join Date: May 2012
Recently, I've also noticed a drop in fuel economy for my 2007 Yaris liftback (67,900 km).
I was happy with getting between 600-640 km/per tank (city/hwy combined), but recently have found it to be roughly between 500 and 540 km/per tank. I found that I got approximately 80 km per "bar" when things were right but need to fill up sooner than before for some reason. Toyota did a throttle body clean and fuel injector service not long ago (63,000 km?) I've just replaced the original Potenzas (almost no tread) with new Michelin "Defender" tires, so I'll see if gas mileage improves a little with those, plus I am due for oil and filter change next week. |
#18 |
did you read my thread similar to this one? I cleaned the MAF sensor, vacuumed airbox and air filter, used some lucas fuel treatment and changed gas brand....as well as summer tires back on.
| Tags |
| 500 kmpl, fuel economy, kilometre per tank, kmpl |
| I can never fill my tank completely? | yarisitis | Fuel Economy Forum | 9 | 12-05-2010 11:51 PM |
| First tank gone | yari09 | Fuel Economy Forum | 3 | 06-10-2010 07:23 AM |
| Filling up using spare gas tank. | Yarimoto | Fuel Economy Forum | 5 | 08-19-2009 04:29 PM |
| Oil catch tank question | window_lee | General Yaris / Vitz Discussion | 1 | 07-14-2009 08:04 AM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
