Old 05-16-2012, 02:18 PM   #1
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Question Fogs that won't light
I installed the fog light per the instructions:
http://www.microimageonline.com/down...ts_install.pdf
http://www.microimageonline.com/down...h%20Wiring.pdf
^this one tells me to remove the wrong resistor, the other one is the one that should be removed as it is the one that will stay on. so now I will have to remove both, unless I just broke the switch all together by removing the one.
I followed all the instructions as they are in both of the above. the switch lights come one but the fog lights do not. also the list image for the second set of instructions says to connect a connector together by the linkage. I only have the male end. no other connector.
1 Do I remove the wire from the switch and connect it to the open connector?
2 Would this be the reason as to why my fog light will not light?
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
