Old 06-03-2012, 04:12 PM   #1
dferguson2
Drives: 2008 yaris sedan
squealing belt
It was over 100 degrees today and the serpentine belt started squealing like a stuck pig, after the car got warmed up, but only when turning the wheel left or right and rolling. It doesn't do it at high speeds like on a freeway or going straight, nor when when idle. The car has over 80k and is 4 years old, and I was thinking of probably replacing the serpentine belt anyway. What troubles me is that if this car had a power steering box, which it don't, why is it only doing it when turning at low speeds. Otherwise the car is quiet as can be, I did check to make sure that nothing was rubbing inside the tire well...I have never heard of a cv joint making such a noise..
dferguson2 is offline   Reply With Quote
Easy fix for Squeaky / Squealing Belt andrewmcg DIY / Maintenance / Service 44 06-04-2025 10:22 AM
Need new Serpentine/Auxilliary belt ras3448 DIY / Maintenance / Service 21 07-16-2013 05:11 PM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
