Old 02-22-2010, 02:57 AM   #1
Murtaza_murti
Drives: Toyota Belta
!!Toyota Belta(Yaris Sedan) Steering Wheel Controls!!
Hi guy's...I'm new here..I wanted to ask that..can I install the Audio Controls on my steering wheel? I mean will I have to change the Air bag module Or something..? Please help me out..!
This is the one I have....
Murtaza_murti is offline   Reply With Quote
Old 02-22-2010, 10:49 AM   #2
At the very least, you need to change the cover that goes over the airbag. Toyota doesn't sell the cover separately, but I've noticed that some ebay sellers offer the cover. Also, in regions where steering wheel controls are not an available option, the spiral cable (aka clockspring) needs to be changed to the one that has the three extra wires for the steering wheel controls.
Old 11-13-2010, 11:55 PM   #3
Murtaza_murti
What if I change my Steering wheel with the OEM one I've pictured above? Will it cause any type of problem? And can I change the Black plastic cover on the top, where the Toyota emblem is at? The reason is that the Steering wheel I am getting has a different pattern on it's plastic cover as compared to my Belta's.
Old 11-14-2010, 08:02 AM   #4
Changing the plastic cover can be done, but might be tricky/dangerous. The plastic cover is riveted on with four large rivets, so they would need to be drilled out.
Old 11-14-2010, 10:23 PM   #5
Murtaza_murti
Okay, but how should it be drilled out?
Old 11-14-2010, 11:04 PM   #6
I personally wouldn't attempt it. Theoretically airbags are designed to withstand heat and vibration, but I think I would try to locate an airbag that fits the steering wheel first.
Old 11-15-2010, 08:30 PM   #7
Murtaza_murti
The Steering wheel I am getting already has a airbag, I need to change the cover's, here are a couple of picture's to show you what I am talking about:
[ATTACH]Steering wheel II.jpg[/ATTACH]
Old 01-05-2015, 01:13 PM   #8
Kar98
Drives: 2011 Scion tC
Very carefully?
Old 02-23-2010, 07:58 AM   #9
Murtaza_murti
Why would I have to change,the cover? I mean what things will I have to buy? Do you know the estimated cost in Dollar's?
Old 02-23-2010, 08:14 AM   #10
Here is an ebay listing for a US one which doesn't support the steering wheel controls (just as an example). There isn't a part number for it, separate from the airbag. Try doing a search of ebay for your area searching for "Yaris airbag cover".
http://cgi.ebay.com/ebaymotors/07-08...Q5fAccessories
Old 08-10-2010, 05:45 PM   #11
Chrsto4
Chrsto4's Avatar
Drives: 2008 Yaris RS 5-dr HB Black
Any news on your search for swapping out the stock and getting the multi-function steering wheel?
___________________________________________
Chrsto4.
Mods: Tinted Windows, Clifford Remote Starter, GPS, Driver's Side Grab Handle, Parrot RK8200 (Sweet)
Chrsto4 is offline   Reply With Quote
Old 10-12-2010, 06:33 PM   #12
Murtaza_murti
^Nah man, Can't get the original one. I'm getting one but it's for a Vitz (Yaris hatchback) the dashboard design is different as compared to the one I have on my Belta.
Old 10-12-2010, 07:42 PM   #13
revolution
Drives: 2009 JDM Toyota Vitz
Where did you manage to find a Vitz one?? I am desperately looking for a multifunctional steering wheel to fit on my 2008 Vitz Hatchback... Let me know!!!
2011 JDM Toyota Vitz RS
NCP91-AHMVK
Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs...
revolution is offline   Reply With Quote
Old 10-14-2010, 08:13 PM   #14
Murtaza_murti
It's an original OEM leather stiched multi-function steering wheel, it costs around 22,000PKR, which equal's to about $250-260. Here is a picture of it.
Old 10-14-2010, 08:38 PM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'll take one! Where do we get it?
― Thomas Paine
Old 10-14-2010, 08:49 PM   #16
Murtaza_murti
Karachi, Pakistan.
Old 10-18-2010, 03:38 PM   #17
revolution
Is it from a Toyota Dealer? If you have a Part Number for it, it would be fantastic.........
NCP91-AHMVK
Old 10-18-2010, 08:19 PM   #18
Murtaza_murti
@revolution no, it's not from a Toyota dealer. I'll try to get the part number.
US '09 5-Door LB: How do you remove the steering wheel? IsLNdbOi DIY / Maintenance / Service 5 06-29-2010 11:50 PM
