Old 06-02-2013, 12:45 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Massive inside wheel spin + outside wheel fender rub
So I went all-out at this weekend's event and noticed some new behavior from my egg: inside wheel spin on sweeping turns and fender rub on the outside front wheel. I realize that adding the S/C has altered the output from my engine, but this seems rather surprising given the other mods on my car.
Here's the relevant stuff:
Tokico blues (OEM bump stops)
Tien S-techs
BFG Rivals (205/50R15) on 15x7 ET42
TRD rear swaybar
Blitz S/C
K&N drop-in filter
When I mounted my suspension this spring I attempted to set the camber as far negative as it could go on the stock bolts, but haven't tried aftermarket crash bolts yet.
Fixing that seems pretty easy, but I see there being a few solutions to the wheel spin: LSD, stiffer suspension, body bracing. The LSD seems to be the sure-fire way to kill the inside wheel spin, but it seems that a stiffer chassis or suspension could also help by keeping the wheel in contact with the pavement more firmly.
So where do I go from here? I'm sure there are other options out there, but I'm still a novice at setup.
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Wheel spin soloecho2 Tracking, Racing, Auto-X Forum 16 08-30-2011 01:54 AM
what 16" wheel size and tire to not rub on trd springs nerdrage Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 06-30-2011 12:27 AM
Rattle Inside Steering Wheel CaptainYaris General Yaris / Vitz Discussion 1 04-01-2011 07:52 AM
