slowpoke
Drives: 08 blk LB manu. pwr opt & cld Join Date: Aug 2010
Hitch installation problem
Hey all,
I bought a Hidden Hitch and would like to install it ... but I can't get the old bolts off!! I'm using a 12mm wrench and cant get the nut to budge. I think it may be too rusted. Any thoughts about what I can do? -Sam |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
PB Blaster, let it soak, and an impact tool.
Hopefully you mean you can't get the "bolt", not "nut" to budge? The nut is welded on, so you are trying to turn the bolt, not the nut. As mentioned above, soaking it with a penetrating oil will probably be necessary to get it out without snapping it.
boydstir
die grinder cut it off and start over the sedan hitch would be ideal for the liftback so you dont see it till receiver is in place
| Genuine Toyota Hitch for Yaris now available in Canada | voodoo22 | DIY / Maintenance / Service | 8 | 04-22-2014 08:50 AM |
| Where to buy and install a Hitch?? | molinee | Cosmetic Modifications (Exterior/Interior) | 9 | 12-29-2011 06:13 PM |
| Failed Hitch Installation | fmicle | DIY / Maintenance / Service | 7 | 08-11-2010 04:15 AM |
| Sedan Ducktail installation problem | mr_eraserhead | Cosmetic Modifications (Exterior/Interior) | 11 | 10-05-2009 01:39 AM |
| Problem with GTspec strut bar installation | Yawesh | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 03-20-2009 04:55 AM |
