Old 07-27-2011, 09:56 PM   #1
Battlekat
Drives: Yaris 4 door. Sport
Torque converter clutch solenoid issues
I heard this is a common problem with yaris/corolla transmissions.
Car stutters. Check engine light is on.
get trouble codes. solenoid checks outs good. replace anyway. still receive trouble codes.
anyone have experience with this issue? is there something else causing the issue?
Tech wants to rebuild tranny. my wallet is bleeding.
Some mistakes are too fun to make only once.
Battlekat is offline   Reply With Quote
Old 07-27-2011, 10:18 PM   #2
There was a TSB for a torque converter clutch solenoid error code issue on 1st gen Yaris (and 04-05 Corolla), but in the TSB if the TCC solenoid checked out OK, then it pointed to following the standard troubleshooting procedures to determine if it is actually a bad torque converter. Do you know what the actual DTC is?
Old 07-27-2011, 10:38 PM   #3
Battlekat
i think he said simply P0740
Old 07-27-2011, 10:49 PM   #4
The U340 AT on the Yaris doesn't have that code (which was the one for the Corolla). On the Yaris, the ones related to the TCC solenoid are:
P2757: Torque Converter Clutch Pressure Control Solenoid Performance (Shift Solenoid Valve SLU)
P2759: Torque Converter Clutch Pressure Control Solenoid Control Circuit Electrical (Shift Solenoid Valve SLU)
Old 07-27-2011, 10:51 PM   #5
Battlekat
ok i must have misunderstood him. he was talking about corollas having the same problem. i probably just didnt catch it. sorry. it was a lot of information for me.
Old 07-27-2011, 10:53 PM   #6
Battlekat
ill ask him again next time we talk. i appreciate your response
Old 07-27-2011, 10:54 PM   #7
If you can, find out what the code is. On this forum there have been few complaints of AT issues on Yaris.
Old 07-28-2011, 04:41 PM   #8
Battlekat
The code was P2757.
He also said he inspected the torque converter itself this morning and it was perfectly good also.
Old 07-28-2011, 04:50 PM   #9
The code was P2757.
P2757 has quite a few possible causes:
1. Shift solenoid valve SLU remains open or closed
2. Valve body is blocked
3. Shift solenoid valve SLU
4. Torque converter clutch
5. Automatic transaxle (clutch,brake or gear etc.)
6. Line pressure is too low
7. ECM
Considering how many ATs are available with low mileage from wrecked cars for well under $1000, I would probably look at replacement, rather than repair. From what I've seen with tranny shops, most rebuilds end up as replacements, often at a higher expense than a swap out would have been (due to the labor spent in the attempted repair).
How many miles are on your current tranny?
Old 07-29-2011, 11:43 PM   #10
auxmike
auxmike's Avatar
This is the first I've heard about bad A/Ts. I would hope these problems don't arise till at least after 100k...
Old 02-09-2014, 01:05 PM   #11
Cudd23
Drives: 08 2dr
hey guys new to the forum here. i actually just had this code pop up today with 98 thousand miles on the car. it's telling me the solenoid is stuck off, does anyone know if that solenoid is inside the transmission or not.
Cudd23 is offline   Reply With Quote
Old 02-09-2014, 01:09 PM   #12
There are three solenoids within the tranny. All three are easily accessible with the pan removed (but are crazy expensive from Toyota). What specific code are you getting?
Old 02-09-2014, 01:10 PM   #13
Cudd23
Drives: 08 2dr
im getting p2757
Old 02-09-2014, 01:25 PM   #14
im getting p2757
OK. That is definitely the code for the Shift solenoid valve SLU. There are actually 5, not 3, but the SLU is easily replaceable.
You can test the SLU to determine if it is bad or if the torque converter is bad.
You can grab the AT service manual from the Micro Image forum:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 09-05-2017, 11:32 AM   #15
89GLH
Drives: 2009 Yaris 4 door hatch
Anyone got an updated link since Micro Image is gone?
Sent from my VS995 using Tapatalk
89GLH is offline   Reply With Quote
Old 12-28-2018, 12:03 PM   #16
Chiroyaris
Drives: 2007 yaris
P2757
Anyone have any follow up with this code? Mine just threw it yesterday and was wondering if anyone had any info before i take it in. I only have a couple grand in my car with 175k, and it might not be worth keeping. Any info???
Thanks
Chiroyaris is offline   Reply With Quote
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 08:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
