Old 10-01-2012, 03:42 AM   #1
aeroDynamic
Drives: yaris
205/45/17 planning to lower with H&R Sport Springs
Hi guys,
Ive been looking around the wheel, tire and suspension forums for some time and noticed that a lot in 17 inch rims are using 205/40/17 tires.
I replaced my stock 185/60/15 to 205/45/17 with +45 offset. I was wondering if I will be able to drop this using H&R Sport Springs (approx 1.5in drop) without having rubbing issues?
Also, my current fender gap is 5 fingers. I'm looking forward a conservative drop, about 2 fingers.
Our hatch is only 6months old and I'll be using my stock shocks.
Hope you could give me advice.
Thanks!
aeroDynamic is offline   Reply With Quote
Old 10-01-2012, 11:43 AM   #2
vten
I believe with that offset, you'll be alright.
I had 215/35/18 with +42 offset before, lowered with tanabe df210 with the stock struts, and I rubbed slightly on the overfender plastic up front on a large dip.
Old 10-01-2012, 11:35 PM   #3
aeroDynamic
Drives: yaris
Tanabe's are about 2in drop right?
My friend's yaris sedan is running on the same wheel specs as yours. He's lowered using Tein S-tech 1.9in drop and he's having minimal rubbing (unless whenever he's loaded with 5 adults on board).
If I only lower the car by 1.5in, I'm hoping that it will be a safe drop. Our roads here in the Phils. are bad :(
Old 10-13-2012, 03:39 PM   #4
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
no problem with that setup
Old 10-13-2012, 07:00 PM   #5
ciscobear
Drives: Toyota Belta
You should be good bro. With the Teins I would recommend the 40s. That's what I'm on.
ciscobear is offline   Reply With Quote
Old 10-14-2012, 11:49 PM   #6
aeroDynamic
Drives: yaris
Alright, can't wait to drop the car already! those wheel wells and fender gap are huge! hehehe
Tanabe DF lower springs bail_w Items for Sale by private party 4 05-08-2011 03:15 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Which lowering springs should I choose? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-28-2009 05:56 PM
H&R springs johnnypaseo Performance Modifications 1 10-01-2007 08:09 AM
planning to lower my car thegame11 Cosmetic Modifications (Exterior/Interior) 7 03-18-2007 11:49 AM
