Old 06-06-2012, 11:31 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Micro Image center exhaust...
Today was a totally fun day because I got to visit Jeff at Micro Image to take a look at their really cool axle back center exit exhaust...
...and I went home with one.
It's 2.25 pounds heavier than the stock exhaust. One reason is that the tubing is a lot larger. The muffler is a small oval 2 1/4 inch offset port Magna Flow Performance muffler.
the ground clearance is superb as the whole exhaust tucks so nicely up inside the car without anything hanging down, and without anything touching anything else that it shouldnt touch.
I sprayed the whole thing BBQ black (a personal favorite) so that none of the exhaust would show up except just the edges of the stainless steel twin tips.
I really like the simple unobtrusive look with as little of the exhaust visible as possible.
It utilizes the stock spring bolts and comes with matching nuts as the stock nuts are flash welded onto the flange that was removed along with the original exhaust.
The flat oval muffler fits well and lays parallel to the ground.
It has an understated look which I find very appealing. The exhaust uses the two original rubber donuts and lines up perfectly with them when the spring bolts are snugged down. The third mount on the twin tip is a self tapping screw with a small angled bracket that you attach to the crash bar behind the bumper. I just used a little piece of wire to attach the third donut to that angle bracket as there's very little room to work there. It hardly needs to support any weight, because almost all the weight is on the two stock donuts. It's just used to slightly adjust the height of the tip.
...and it sounds even better than it looks.
It's basically silent at idle and you couldn't tell it from the sound of the stock exhaust. Running it has a rich mellow tone with absolutely no raspy ricey overtones. On deceleration it has a pleasant burble like a small European 60's sports car. You really hear it when you step on the gas, but even then it still retains its rich deep warm tone with no other extraneous irritating noises.
In my opinion, this was a very well thought out product design. My thanks to Garm and Jeff for producing a really fine and unique product that no one else makes.
Old 06-06-2012, 11:38 PM   #2
whoa, double post! :D
Old 06-07-2012, 12:17 AM   #3
tooter
play every day
tooter's Avatar
Hey Garm... what happened???
I was responding to your post and a message came up "invalid link notify administrator"... then my post disappeared.
Again.
If there were any notable negatives to your exhaust, I'd certainly say so.
By the way, I resolved the stainless question simply by looking it up on the internet. Your exhaust is all stainless with the only exception being the small concave two bolt hole bracket which accepts the stock donut gasket. It had surface rust on it, but nowhere else was there even a trace of rust including the welds. The Magnaflow mufflers are listed as either "polished stainless", or "natural stainless" (unpolished). None of them are listed as steel.
When chromium and carbon are added to iron, they make it strong and stainless which is typical of cutlery... and they also make it magnetic. (I personally verified this by determining that all of our stainless kitchen knives stick like crazy to a magnet... and none of them rust. ) The highly polished twin tip is nickel stainless, because when nickel is added the alloy becomes non magnetic.... but it's also softer. I believe the softer less structurally critical nickel alloy sheet metal is easier to form into the intricate contours of the tip.
Old 06-07-2012, 09:31 AM   #4
No idea; it's not my forum.
Old 06-07-2012, 11:44 AM   #5
tooter
play every day
tooter's Avatar
It's ok... I saw your original post before it disappeared.
And thanks for the nuts!
They worked perfectly. Now the original bolts can bottom to their flanges and compress the springs just right. It's amazing how well the exhaust reoriented itself with the spring bolts snugged down properly. There is almost no weight on the third non stock point of attachment at the tip which is good. I haven't yet figured out how to attach it because space is really tight up in there. If the donut is attached to the angle bracket first, the self threading nut can't be accessed to tighten it to the lip of the crash bar. So I just used a piece of wire to connect the donut to the angle bracket and tightened the wire to get the height just right. Since there is almost no tension on it at all I'll probably just keep it that way.
Your exhaust sounds so nice even my wife likes it. ... and that says a lot.
Old 06-07-2012, 04:01 PM   #6
should have picked up some lowering springs! ;)
Old 06-07-2012, 04:14 PM   #7
tooter
play every day
tooter's Avatar
Oh there were plenty of them there as well as really cool coilovers. But I live in a rural area with some dirt roads and prone to winter flooding. Ground clearance has practical value here so I won't be giving it up. That's what I like about the MI exhaust. it Doesn't compormise ground clearance one little bit.
Old 06-07-2012, 04:38 PM   #8
SAV912
Pirate Yaaaaris
SAV912's Avatar
Tooter, is there a way you can get a sound clip of this? I've been eyeballing it hard since it is readymade instead of going forward with my own center exit exhaust. Looks great although I'll probably leave mine polished if I order one.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 06-07-2012, 05:24 PM   #9
tooter
play every day
tooter's Avatar
Be happy to...
My wife took the car to town today and I'm working tomorrow, so maybe on Saturday if there isn't time later today. Garm also took a sound clip when I was there, so it may turn up on his website later on.
A muffler shop would have a difficult time beating the superb fit. And that's the distinct advantage of a complete ready made assembly, the engineering has already been built into it. Jeff showed me the original prototype when I was there.
Old 06-07-2012, 10:08 PM   #10
tooter
play every day
tooter's Avatar
Here's a link to the YouTube sound clip:
http://www.youtube.com/watch?v=nQjo6...ature=youtu.be
I put the microphone really close as the sound is pretty mild from a distance.
Old 06-07-2012, 10:54 PM   #11
yPod09
All black everything.
yPod09's Avatar
Drives: '09 5dr All black.
OH MY GOD! I am NOT that into exhausts, but that sounds AMAZING! It is like a lion!
Which Magnaflow muffler is that?
AND does the fact that you have different headers change the sound?
Thanks for a great thread AND the audio!
yPod09 is offline   Reply With Quote
Old 06-08-2012, 12:28 AM   #12
tooter
play every day
tooter's Avatar
Well, don't forget the microphone was only 15 inches away from the exhaust tip!
I'm not sure exactly which one. It just has "MagnaFlow Performance" stamped into the shell. Garm should know exactly what it is. All I know is that I really like it.
It's an offset port muffler which makes the sound more mellow than a straight through.
I don't know as the 4-2-1 header was installed first. I do know that it made no difference in how the stock exhaust sounded, so I don't think so as the midpipe is totally stock with both resonators and catalytic converter intact.
It's my pleasure.
Old 06-07-2012, 11:49 PM   #13
kimona
kimona's Avatar
Drives: 2014 White VITZ
I love it!
Old 06-08-2012, 01:03 AM   #14
SAV912
Pirate Yaaaaris
SAV912's Avatar
I'm sold. It being center exit AND being from a trusted source. Now to come up with...gulp...$449.
-C
Georgia Bulldogs!
Old 06-11-2012, 12:09 PM   #15
ViosFan
Man, really wished this could come out for the sedan
ViosFan is offline   Reply With Quote
Old 06-11-2012, 12:41 PM   #16
tooter
play every day
tooter's Avatar
Is the difference just the body length, or are there other structural differences in the chassis itself?
Old 06-11-2012, 01:00 PM   #17
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
I wish too :(
Interior:ALL red, black roof
Old 06-13-2012, 10:56 PM   #18
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Originally Posted by packetrace View Post
I wish too :(
I can make something for the sedans...even a small run of them i can use my car as a.jig vs. building a jig for a limited run.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Micro Image lowering springs 1.8" drop markylicious Middle East 144 10-30-2011 01:18 AM
Micro Image Short Shift Kit- prototype review mazilla Performance Modifications 124 09-26-2011 06:04 PM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
Micro Image meet Jan 30, 2010 Brian Photo-Video-Media Gallery 57 02-06-2010 10:27 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
