Old 03-06-2007, 10:04 PM   #1
AFR running extra rich at WOT?
I'm not sure if anyone here has an air-fuel ratio sensor on their car, but hopefully someone knowledgeable can help me with this.
Normally the ratio flicks between rich and lean, from what I understand this is normal, just the ECU's way of improving the catalyser's performance.
But, I was on the highway the other day, in 5th gear, pedal to the metal, crawling along the traffic (), and I was checking my AFR gauge, which was stuck pretty high, at a little under 12:1. When this is the case there is also a slight sulphurous smell pervading the cabin.
So, as my ECU has not been touched, is this rich ratio normal in these situations? From my understanding it should be running maybe a little lean in order to extract maximum power, right? Or could this be a result of a faulty/dirty MAF sensor, or just my AFR gauge being stupid?
Old 03-07-2007, 04:42 PM   #2
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
well ur pedal to the metal right, so throttle wide open, shouldn't the ECU sense a wide open throttle and asume u wants power, rich mixture more juice gives u more power. From my knowledge during wide-open throttle ECU will run with pre-set configurations ignoring couples like MAF and O2.
i can read some articles on EFIs
http://www.autoshop101.com/autoshop15.html
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 03-07-2007, 08:39 PM   #3
Yeah but the thing is, contrary to popular belief, a richer mixture does NOT give more power! The main use for an over-rich mixture is to provide a cooler burn of the air-fuel mix, to reduce the chance of knocking, most especially in a turbo application. It also causes a lot of fuel to be unburnt, which results in worse emissions and mileage.
In order to get the most power out of a normal air-fuel combustion, the ration needs to be stoichiometric (14.7:1) or very slightly lean.
Anyway I got some free time today, I'll try to reset my ECU, clean my MAF sensor and see if this helps. Also (doh), I just reread that thread about the TSB for the catalyser linked to the sulphur smell, I don't know if that is an option here but it may solve that part of the problem.
Old 03-08-2007, 02:19 AM   #4
ChinoCharles
Drives: LB
First thing I thought, but its cool we might have just found why it was recalled and why it smelled like that. I want an AFR gauge!
Thomas, do you have a fuel pressure regulator on that thing?
Old 03-08-2007, 02:35 AM   #5
An AFR gauge is kinda annoying most of the time as it just goes up and down, as the ECU normally normally switches between lean and rich to maximize the efficiency of the catalyser. But in this case it's kinda handy
No fuel pressure regulator, would it do any good with a stock engine though?
Old 03-08-2007, 02:46 AM   #6
ChinoCharles
Drives: LB
Your engine is stock!?!?! You need to fix that!
Old 03-08-2007, 02:56 AM   #7
ChinoCharles
Drives: LB
Betty!
Old 03-08-2007, 03:05 AM   #8
Betty!
Oh I already have a bastardised intake...
but, as I mentioned in your thread, the only reason mine is not shorter is because of that breather tube, I did not want to remove that first piece of tubing... But now I might just try it
Old 03-08-2007, 05:44 AM   #9
http://en.wikipedia.org/wiki/Air_fuel_ratio
Oh well, this explains a lot, looks like it does not only affect forced induction situations, and I guess I'll just shut up now
Now, I wonder if this rich mixture is affected by the actual engine's knock sensor, or if it is a pre-mapped setting... Time to try some higher octane fuel (less chance of knock) next time and see what happens
A stoichiometric mixture unfortunately burns very hot and can damage engine components if the engine is placed under high load at this fuel air mixture. Due to the high temperatures at this mixture, detonation of the fuel air mix shortly after maximum cylinder pressure is possible under high load (referred to as knocking or pinging). Detonation can cause serious engine damage as the uncontrolled burning of the fuel air mix can create very high pressures in the cylinder. As a consequence stoichiometric mixtures are only used under light load conditions with more fuel added for acceleration and high load condition to prevent detonation and to cool down the combustion gasses.
Old 03-08-2007, 07:59 AM   #10
punch
punch's Avatar
wideband afr guage would work on our cars better.
punch is offline   Reply With Quote
Old 03-08-2007, 09:17 AM   #11
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
A narrow band AFR guage is useless. Get a wideband for a more accurate picture of what is going on.
Higher octane will not change your AFR. the car will run 14.7:1 in closed loop while putting around, but in WOT situations the car needs more fuel to keep EGTs down. This is a scenario where it is not practical to run the theoretical limit because you will harm the engine. This is typical in ALL cars, and more pronounced in FI applications.
Your intake could very well be contributing to this issue. While I wouldn't call just below 12:1 too rich, but it could probably be leaned out a bit safely. Generally intakes make power by leaning the car out a bit, but yours has a tight 180 degree turn right before the MAF that could be throwing things off a bit.
Ashley
Old 03-08-2007, 11:18 AM   #12
ChinoCharles
Drives: LB
Ashley, could you suggest a wideband that would work well for a Yaris?
Old 03-10-2007, 11:10 AM   #13
largeorangefont
Break'em off some.
Sorry I missed this.
http://www.rpmoutlet.com/aemgauge.htm
That is the AEM wideband. $279 is about the best I have seen.
If you don't want a round guage, Dynotune has the Innovate wideband with a small digital display. You can get it with a red or green readout. This is $279 as well.
This is the wideband I run in my Mustang, just with the Innovative round display as opposed to the square display
You can find it here
http://www.dynotunenitrous.com/store...?idproduct=150
Also, Autometer just came out with their own wideband that will match your tach. $349 from Summit.
Ashley
