View Poll Results: Dumbest thing you have done to your Yar so far
Put a CB antenna on it 1 50.00%
Put rims that look funky/gay/stupid on it 1 50.00%
wreck it 0 0%
let it sit outside in a hail storm 1 50.00%
eyelashes 0 0%
put cheap tires on 0 0%
put off doing brakes then run into something 0 0%
upgrade all performance items except brakes 0 0%
let your friend/wife/husband drive it and they bruise it 1 50.00%
other item not listed, come up with more questions in another poll on your own 0 0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Old 11-19-2014, 02:02 PM   #1
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Cool CB antenna
I found that when traveling, rather than have an out of date police radar detector, or a new expensive one, I go with a CB instead. Truckers usually alert to incidents on the road, and the plain wrapper Dodge hiding in the brush.
There are others uses, but, that is what I would use it for.
It is not legal though, to take your police scanner in the car, even though they sell adapters at radio shack for your scanner there. But, in any case, the CB antennas are for specific frequencies anyway, and won't work as well with a CB antenna anyway. (haven't tried it yet)
Nowhere real good to put a CB antenna on, not a fan of magnet mounts.
So, I researched and found the Firestik II 4 footer to fit the need (wanted a 5' but hard to come by).
I put a hitch on, and one day I will get a small trailer to haul light loads, straw for the dogs, maybe some remodel project or lumber and whatnot.
But, for now, it is a CB mount. It looks like I could still haul a trailer if I wanted to, but not in the immediate plans anyway.
I snapped some shots of it. It does lay back some in the wind at 80 mph, but, I couldn't see the red tip, so not too much layin over.
I got the L brackets and nuts and bolts at Home Depot, I got the firewire, spring mount and firestik from Amazon, and they are all Firestik authentic stuff. I ran a ground from inside the trunk to the antenna base, and ran the firewire beside the ground, then under the rear seats to the right of the center console, where I have an old CB mounted. I have 2 old CB's, both Cobra's.
This would be maybe not a good starter thread, but maybe good inside of a sticky thread maybe someone can recreate if not done yet....
What did you do to your Yaris this weekend ?
Stubby antenna in the car wash? DebbyM46227 In Car Entertainment + Electronics (audio / video / alarm) 6 05-23-2014 08:32 PM
Replacing roof antenna. Need info on a plug. 2005vitzRS In Car Entertainment + Electronics (audio / video / alarm) 3 03-13-2014 06:49 PM
Euro Style Antenna (Small Antenna) Saity Items for Sale by private party 9 12-12-2009 09:23 PM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
car antenna question mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 6 12-12-2008 01:41 AM
