Old 07-13-2007, 06:36 AM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
De-cat exhaust system
Hi guys , has anybody had a de-cat done on their yaris , if so have you had any problems? any info will help as i want to de-cat my 1.3.
Thanks
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 07-13-2007, 09:47 AM   #2
Capagotks
Chode
Capagotks's Avatar
Drives: Silver 5 Door YRX 1.5L I4
Send a message via MSN to Capagotks
i know a friend who de-catted their RX-7. Here (and probably in most parts of the world) it is illegal to remove the cat, as it removes most of the toxic gasses from the exhaust. (im pretty sure you can take it off for show cars/race cars). You will get a significant HP increase, but it is easy to notice if you have it off because if you rev it, flames might start coming out (and not just the occasional small one, i mean FULL ON) and your eyes start watering if your in a confined space/revving it up at the lights (but mainly for the people behind you)
Capagotks is offline   Reply With Quote
Old 07-13-2007, 10:13 AM   #3
thomasward00
thomasward00's Avatar
Drives: 2007 Yaris Sedan
Remember that our stock engines were designed to operate with a certain amount of back pressure, taking the cat off some stock engines will cause premature valve seal failure, it's not worth the gain, and besides it will kill your lower end.
thomasward00 is offline   Reply With Quote
Old 07-13-2007, 10:15 AM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
As Capagotks mentioned, the catalytic converter is there to greatly lessen your vehicle's emissions. If you remove it you will be dumping a lot of noxious emissions straight into your local atmosphere.
- Brian
Share the Road
Old 07-13-2007, 10:45 AM   #5
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
thanks for all the advice guys , i really appreciate it!
JDMtuner
www.jdmtuner.co.za
Old 07-13-2007, 11:51 AM   #6
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
OBDII cars (every car made post-1996) have 2 O2 sensors, one before and one after the cat to verify cat performance. Remove or gut the cat, you'll get a check engine light.
A high flow cat flows just as much as a straight pipe, doesn't give the CE light, and will pass a sniffer test.
There is other issues with gutting a cat, including turbulance and killing yourself slowly with the nasty crap that goes into a cat.
Thats something specific to a rotary. Because of how the work, alot of gas enters the exhaust and ignightes easily.
Scooby's do it too, cause they are a boxer. Especially bouncing off the rev limiter.
Most other cars it takes something wrong with them to do it.
WRBlue is offline   Reply With Quote
Old 07-14-2007, 05:07 AM   #7
Capagotks
Chode
Capagotks's Avatar
speaking of rotaries, do you think onw would fit in a yaris, mounted sideways, and even if the front bumper had to be extended?
Old 07-14-2007, 07:20 AM   #8
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
Absolutely, if you get the chance, check out the size of those lil engines. Tiny. But you're wallet will have to match the size...and you have to consider that you can't run FWD, as far as I know, there are no FWD rotories worldwide, so the swap would have to include a RWD conversion...but I'd love to see this done, in pretty much every platform...ooohhh the fun possible with 10k redlines and turbos
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 07-14-2007, 09:55 AM   #9
Black Yaris
der Zeck
Black Yaris's Avatar
only thing that is still stock on my exhaust is my cats, and only the cats... everything b4 and after has been opened up to larger diameter pipe.... and no CEL's
Old 07-15-2007, 01:26 AM   #10
WRBlue
A 12A is smaller than a beer keg ;) lol
But there was a FWD rotary. A crappy NSU, the Ro 80. The engines were crap - needed rebuilds at 30k, and all the cars came with an auto.
You could adapt a FWD tranny to a Rotary, but it'll be pricy.
Then there was the Norton Commander and the Suzuki RE5 - Rotary powered motorcycles. Those would definatly fit :D There are ways to adapt them to power a car FWD, but the Suzuki was only a 500cc making 60hp... It'd be alot lighter, but it would be hard to get over 120hp out of it. lol
Old 07-16-2007, 12:33 AM   #11
Capagotks
Chode
Capagotks's Avatar
what about a Suzuki GSX1300R (Hayabusa) engine? its not a rotary, but produces 129kw (175 HP) and its only 1299 cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC. (from wikipedia), so I reckon it would easily fit in the yaris, and the 2008 model is bigger with 1340 cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC and a compression ratio of 12.5:1 (up from 11:1). Then turbo it. then you've got yourself a deathtrap on wheels.
Old 07-16-2007, 12:35 AM   #12
Capagotks
Chode
Capagotks's Avatar
or even better, the Kawasaki Ninja ZX-14, with 1,352 cc Liquid-cooled, 4-stroke In-Line Four, 12:1 compression ratio, DOHC, 16 valves, fuel injection, digital ignition, electric starting 140 kw (187 hp) @ 9,500 rpm; 147.1 kw (200 ps)(197 hp) @ 9,500 rpm with RAM air; 154 Nm (113.5 lb/ft) @ 7,500 rpm and a 6-speed transmission.
Old 07-16-2007, 02:57 AM   #13
jdium
Mr Attitude
jdium's Avatar
Sounds kinda like this:
http://www.youtube.com/watch?v=xLVQtK04lig
SmartCar with a GSXR1000 in it...
Old 07-17-2007, 07:33 AM   #14
Capagotks
Chode
Capagotks's Avatar
pretty much. fool everyone in the bike lanes....
Old 07-17-2007, 07:45 AM   #15
bike engines are nice, but they need to be revved up to crazy speeds to make much useful power. That's not too much of a problem on a bike as weight is very low, but a car is far heavier, wouldn't make things very sluggish at lower RPMs?
Although, I suppose, with this kind of swap, you wouldn't want to drive at low RPMs ever!
Old 07-17-2007, 02:17 PM   #16
Motorhead6T5
Motorhead6T5's Avatar
Drives: 07 NCP96
If you delete the cat you will need a mil elim,since the ecu cannot be reflashed to turn the rear 02 circut off(yet). A mil elim is a malfunction indicator lamp eliminator. Its baisicly a resistor that tells your ecu that it is getting a clean reading ,it is pluged into the rear o2 harness.
Motorhead6T5 is offline   Reply With Quote
Old 07-18-2007, 04:01 AM   #17
Black Yaris
der Zeck
or you can do it the easy way and get defoulers for a few bux
Old 07-18-2007, 04:32 AM   #18
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
I decatted and race-piped the Yaris last week... top end is GREAT... low end is brutally underserved. It did improve over 3-4 engine cycles, and it's in preparation for some un-normal aspiration, but now I am pondering Supercharger over Turbo!
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
FS/FT: Toyota Borla Performance Exhaust System nevermorez Items for Sale by private party 16 06-01-2007 09:36 PM
Non cat exhaust CEL? CASTREX Performance Modifications 15 01-28-2007 01:22 PM
Who have the exhaust system from Toyota (Canada)? SimmZ Performance Modifications 10 08-18-2006 12:15 PM
