Old 01-31-2009, 04:18 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
How do I cure a lean condition?
What's my next step? It appears that with the Blitz supercharger and its piggyback fuel controller, I'm running lean.
Should I swap in larger injectors? The piggyback fuel controller is not adjustable so I cannot change the duty cycle any further.
Before: air/fuel mixture ran between 11.35 and 13.6
After: air/fuel mixture ran between 13.45 and 14.91
Old 01-31-2009, 06:08 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I would say bigger injectors as a first step. Maybe an upgraded fuel pump as well
Old 01-31-2009, 06:14 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
fuel pump is fine
bigger injectors would definitely help. source a set from a celica gts or a scion tC (i run tC injectors) you can find them both for cheap (i got mine for free, make friends with a service tech at toyota)
until then, STAY OUT OF BOOST, you're gonna blow your engine running lean like that on boost.
Old 03-15-2009, 09:51 PM   #4
PHXDEMON
PHXDEMON's Avatar
fuel pump is fine
I just assumed something the size of a D cell battery would be stressing
Old 03-16-2009, 12:03 PM   #5
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I just watched the Youtube video. It looks too lean under boost, unless the timing has been retarded by the SC adjustment box (which could be the case). The first cat is not falsifying your AFR readings much. Clearly your wideband is very close to accurate because you are seeing 14.6 AFR during cruise.
Only way to tell for sure would be to datalog the timing, or get an EGT gauge, or both. Either way, the car would benefit from a tune, probably in the neighborhood of 15-20 HP.
Old 01-31-2009, 06:52 PM   #6
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Whats the duty cycle like on the injectors already?
if you don't have the ability to change the constant of the injectors with the controller, make sure you scale properly so you wont have to do too many adjustments.
Old 01-31-2009, 10:13 PM   #7
ddongbap
Lean is no good.
Old 02-01-2009, 12:26 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by ddongbap View Post
Lean is no good.
http://www.youtube.com/watch?v=JhQMAmnOBxA
Lean back sucks even more
Old 02-01-2009, 12:32 AM   #9
LtNoogie
LtNoogie's Avatar
I don't know what that had to do with this thread but I enjoyed the mix.
Old 02-01-2009, 12:33 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
the captain obvious "lean is no good" post.... i figured i'd add my own "obvious" post.
the remix is good because snoop is in it.. snoop can fix any crappy song
Old 01-31-2009, 10:30 PM   #11
Just curious, why were the two dynos done in different gears?
Call Blitz USA. THAT is the first thing to do. Show them the problem. If you further modify your car to fix something that should be working properly in the first place, they are not going to be helpful at all.
You could also share on here under what conditions your getting those readings:
Idle cold =
Idle warm =
Boost off, light pedal =
Boost off, WOT =
Boost on, light pedal =
Boost on WOT =
The Blitz r-Vit gives some control over air/fuel. Maybe they'll give you one.
Old 01-31-2009, 11:02 PM   #12
hard to say what to do...is it your fuel injectors being maxed out or the blitz ecu being unable to cope with the s/c AND i/h/e?
Old 02-01-2009, 12:27 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
well, considering the xB GREDDY turbo kit does not upgrade injectors, i would guess that stock inj should handle the duty cycle just fine on an SC application
http://www.rceng.com/technical.aspx
Old 02-01-2009, 12:35 AM   #14
LtNoogie
LtNoogie's Avatar
I've actually not had any problems with detonation so today's readings surprised me. This gives me more incentive to get off my ass and install my wideband a/f gauge. I sent a message to yarisdarkness, who works for Blitz, since their website does not list a email address.
Old 02-01-2009, 12:37 AM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
make sure and install the wideband PRE cat..
what did you buy? i have an innovate LC1
Old 02-01-2009, 12:44 AM   #16
LtNoogie
LtNoogie's Avatar
I screwed up and had the bung welded on after the first cat because I did not want to pay to have the muffler shop drop the front of the midpipe to put a bung near the header. I'll bite the bullet and have them do it correctly. The first bung is currently plugged.
I have an Autometer C2 with digital LED readout and the colored LEDs running across the outside edge. I also have a C2 Vacuum/Boost gauge.
I've been putting off installing them because I hate running cables into the car.
Old 02-01-2009, 12:54 AM   #17
LtNoogie
LtNoogie's Avatar
Unless I'm missing something, the O2 sensor is on a 1 foot harness with a connector at the end. A 9 foot harness goes between it and the meter itself.
The data logger in the pdf file does not come with the kit.
Old 02-01-2009, 12:56 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
1 foot is really , really short.
you'll probably want to have the bung welded near where the shift linkage comes thru the tunnel, then route the cable thru that cover and put the "brain" up under the center console.
Lean Burn - Hydrogen Enrichment GeneW Fuel Economy Forum 20 07-23-2010 02:59 PM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
WTB or free front bumper any condition in SOCal Walter Items for Sale by private party 3 09-14-2007 12:56 AM
