Old 03-21-2013, 03:33 PM   #1
VeryWetDog
Drives: Toyota Yaris
Speed sensor fault?
I have just put my old 2002 Yaris 1L GS back on the road for my daughter. It has been off the road for 6 months and now the speedo has stopped working. It displays 0 mph all the time. Had always worked fine before.
Could this be due to a faulty speedo sensor, if so where is it ?
Thanks, Dan.
VeryWetDog is offline   Reply With Quote
Old 03-21-2013, 03:40 PM   #2
It could be the speed sensor (which is a small device mounted to the top of the tranny), or it could be the speedometer itself. Plugging in an OBDII test tool would let you see if the ECM is getting the signal from the sensor, and if so, then the problem is the speedometer, rather than the sensor.
Old 03-21-2013, 04:17 PM   #3
VeryWetDog
Thanks for the advice. Will see if I can get hold of an OBDII test tool off ebay and take it from there.
Old 03-21-2013, 04:43 PM   #4
Just make sure that you verify compatibility of the device with your car. I am not 100% sure about which protocol your vintage of Yaris supports.
Old 03-23-2013, 08:40 AM   #5
VeryWetDog
Just noticed ODO has not been going up and after resetting average mpg / speed counters they are not working ether. Before I spend money on a tool does this mean anything?
Old 03-23-2013, 09:36 AM   #6
That makes it more likely to be the speed sensor itself.
Old 03-23-2013, 09:29 AM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got a couple of spare speed sensors, but I would need more details about your car to verify the part numbers. Specifically, what gearbox and frame number?
Old 03-23-2013, 10:30 AM   #8
VeryWetDog
Thanks for your help but I fixed it with a slap. The whole display turned off while driving, so I gave it a slap an it all came back on including the speedo, it worked for a few minutes and stopped again. When i got home i took the cover off the dash and found a loose plug pushing it in securely and it's now all working. :-)
Old 03-23-2013, 12:25 PM   #9
CrankyOldMan
Curse you Sumitomo and your flimsy double-retention automotive connectors!! =)
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
Car Race/IDLE/initial speed Problem mamun22s DIY / Maintenance / Service 0 08-28-2012 06:29 AM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
