Old 04-14-2013, 08:02 PM   #1
Monstro
Drives: 2010 Black Yaris Lb
Whiteline Polyurethane Bushing Review
Hey guys, just wanted to tell everyone about a great upgrade for handling!
I installed Whiteline synthetic elastomer control arm bushings and I have to say wow! The car feels much more planted through turns, especially mid-corner. It also seems it reduced a good amount of under-steer during initial throttle application, I am not sure if that is because of a reduction in front end compliance though. Be aware that you will have issues installing these if you have a sub-frame brace, due to these bushings being much less compliant; also always perform an alignment after any suspension work. Bumps are a little more noticeable, but not bad. All in all a very good modification.
Supporting mods.
TRD suspension kit
TRD rear sway bar
GTSPEC front, mid, rear chassis bracing
Ultra racing front strut brace
Team dynamics 15x6.5" et +38mm Monza R wheels
195/55/15 Hankook Ventus v2 tires
Monstro is offline   Reply With Quote
bushing came off metal sleeve on rearstrut? tein coilover TRD.RiC Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-18-2012 11:14 PM
alternator bushing JAMMED ! Siffleu DIY / Maintenance / Service 12 10-22-2010 11:12 AM
Polyurethane? Bushing Kits? bronzebullet232 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 06-18-2010 04:45 PM
Review of the 2009 5-door and 3-door Yaris Liftbacks csburdick General Yaris / Vitz Discussion 14 01-03-2009 08:09 PM
