Old 03-27-2010, 07:30 PM   #1
IGGGY
Drives: 07 Hatchback
Headlight Lens Showing Age
I have an 07 HB. The leadlight lenses are starting to get a bit foggy. Anyone know of a product to clean/restore the lens?
IGGGY is offline   Reply With Quote
Old 03-27-2010, 07:34 PM   #2
yarrr
Drives: 07 sedan
meguiar's plastx, or the whole restoration kit if you really wanted
http://www.meguiars.com/estore/produ...ectionID=15101
yarrr is offline   Reply With Quote
Old 03-27-2010, 11:59 PM   #3
Vang
Drives: 2008 Yaris Sedan
this 100%~!!
is it yellowish or is it water leaking inside and fogging it up?
Vang is offline   Reply With Quote
Old 03-30-2010, 04:25 AM   #4
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
really good
http://www.youtube.com/watch?v=ggO4G0iEcnk
yaris 2sz is offline   Reply With Quote
Old 03-30-2010, 12:22 PM   #5
RedRide
RedRide's Avatar
Originally Posted by yaris 2sz View Post
The local Macco has a big sign hyping a "special" They will buff out your yellowed headlights for only $99.95!
I have found that best way to prevent yellowed headlights is to simply wipe them whenever you wash the car and sometimes when they are just wet due to rain as the "yellow" is mainly dirt build up.
I have followed this cleaning ritual with my '02 celica (that I got in '01) and the headlights are still crystal clear even though it is not garage kepted.
I have seen so many cars with shiny, well maintained paint and yellowed headlights. It seems to many that cleaning the headlights is just an after thought at best.
Old 03-27-2010, 09:57 PM   #6
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
When you wax your car, wipe a little on the lens. This will offer some protection from the sun.
Old 03-28-2010, 12:22 AM   #7
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
if they are not too far gone and the hazing is on the outside Plexius is fantastic for plastic lens preservation. Availabe at most motorcycle shops it was invented for plexiglass on aircraft. It really works. Being your car is only a few years old I'd hope you don't need restoration yet. My '08 lamps look as clear and shiny as the day I bought it using Plexius after I wash the car. Hazing/yellowing of clear plastic headlamp lenses is normal-I have yet to see a car with plastic headlamps not do it after a few years-they all require something to keep them looking good. It's all a combination of engine heat, uv's, ozone slowly aging them.
UTVitz is offline   Reply With Quote
Old 03-30-2010, 12:21 AM   #8
yaris2010RS
yaris2010RS's Avatar
best produst i have ever used is called plastex or soemthing. it makes the lights (and anything else plastic) look brandnew. it removes the glazing and yellowing and also rock chips. its really a great product. i can't wait for a few years down the road for when i can use it again! lol
u can get it at any canadian tire..... or for those unfortunate to not be canadian or near a canadian tire any auto store (auto zone and parts source)
Old 03-30-2010, 02:21 AM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Get any kind of polisher and just stick a cloth to it for a few minutes per lense. Worked wonders for mine.
EDIT: I say any kind because I used a metal polisher and it works fine, so pretty much anything will do.
Old 03-30-2010, 03:47 PM   #10
Lucas13
Drives: 07 Yaris LB
Headlight Haze is something very common on every vehicle knows days, no matter how expensive the car is. Car headlights are made of polycarbonate and they are protected by a silicone based clear coat which can last about 3 years or more depending the conditions, for example in Florida most of the vehicles after 4 years need headlight restoration. Why this Happen?
Acid rain, Oxidation, pollution, Saline environment and road debris cause that the silicone based UV coating starts to break and will expose the polycarbonate.
In some cases the headlights can be deoxidized with some of the kits available in local stores but sometimes the haze will re-appear after 3 months, when the UV coating is already broken its necessary to re surface the headlight. Is always good to keep in mind that the headlights condition depend on how you take care of them; I always recommend using some type of wax cleaner to keep all the contaminants away from the UV coating and at the same time to keep them sealed, using a good sealant will help them to last longer.
I own a headlight restoration business, and this how I make a living, I find that know days there are lots of kits available but none of them will offer a permanent solution, there are some places that charge a lot for this process but you need to make sure what they use because some of them including my local Toyota dealer use this kits and I think this is not honest from their part since it's not done with professional tools and products and the result is that the haze will re-appear within months. Real headlight restoration takes re appying the silicon based UV protectant coating, doing it that way will make the headlights will last for years without the maintenance.
This is very simple website I made so my customers can have a better idea of headlight restoration the importance and also there are some pictures of before and after. www.headlightexpert.com
Lucas13 is offline   Reply With Quote
Old 06-04-2010, 07:25 PM   #11
yarisboi
Drives: Yaris 1999 3dr
once i've polished my headlights can anyone recommend a way i can apply a layer of this silicon based UV coatings? i'm sure there must be something i can buff on buff on or something but i've done a few searches and cant find anything specifically for polycarbonate (seen it for glass - would this work?)
thanks for the help!
yarisboi is offline   Reply With Quote
Old 06-13-2010, 12:24 PM   #12
Lucas13
Drives: 07 Yaris LB
You can try to find Renulite or similar product, it comes in spray.
Old 06-16-2010, 05:19 PM   #13
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Dude , wax works perfect .
Old 06-13-2010, 04:48 AM   #14
yarisboi
ok i can vouch for the effectiveness of the metal polish
i used Autosol metal polish (the one in the tube) and it works wonders. Seriously effective.
I still need something a little more permanent which will leave a layer over the newly polished headlights so that they don't discolour so easily again.
Old 06-16-2010, 08:02 PM   #15
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
www.griotsgarage.com their glass polish works perfectly on headlights,I have used it on about a dozen cars now.....all of them had plastic lenses except for one......then a coat of wax or polish once done and they are good as new.
Old 04-17-2013, 11:30 PM   #16
indepth2
Drives: 92 volvo
There are a lot of products and methods people use to adddress that problem but there are drawbacks to most. The use of abrasives is the most common but also the most damaging method to both the surface of the headlight lens and protective UV layer. The newer your headlight the less likely you need an abrasive cleaner. The safest and fastest way is to use an acrylic lens deoxidizer. It is a liquid non abrasive and will not harm the headlights protective Ultra Violet layer : http://www.ibc34.com/Onestep.html This won't work on a lens that is damaged and needs to be resurfaced but it is perfect for the instanteous removal of surface oxidation which is the most common problem with all acrylic headlight lens.
indepth2 is offline   Reply With Quote
Old 04-18-2013, 03:56 AM   #17
MyzticZ3r0
look at the OP's date.. thread resurrection!
MyzticZ3r0 is offline   Reply With Quote
Old 04-18-2013, 10:14 PM   #18
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
Use Flitz and elbow grease. Will not harm paint.
http://www.flitz.com/p-16-flitz-polish-paste.aspx
Killchain is offline   Reply With Quote
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Canon Rebel G Body, Canon 35-80mm AF lens, Quantaray 70-300mm Lens TinyGiant Items for Sale by private party 6 07-08-2009 12:20 PM
