![]() Drives: 2012 Yaris LE Join Date: Mar 2013
I'm going to be towing my Yaris automatic with a tow dolly behind my motorhome. Should I put the transmission in park or drive? Thanks
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
front wheel on the dolly and it can be parked, it is the rear wheels that are going to be rolling, just don't put the parking break on.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
If you are towing it on a dolly, the rear wheels will be in contact with the road and the fronts will be lashed to the front wheel pockets. You don't want it to come off the dolly, so it makes sense to prevent movement against the straps by putting the tranny in park. Just make sure you do not put the ebrake on.
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
Can MT Yarises (or corollas for that matter) be towed 4 wheels down? I'm fairly certain AT ones can't but I've seen some local transporters using an Echo and/or Corolla towed 4 wheels down.
MT's are fine to tow with all four wheels down (in neutral). AT's should never have the drive wheels in motion unless the engine is doing it.
Only Happy When it Rains
I would never do it, because at least on the old mechanical odometers, that mileage, even with the car completely off, added to the total.
Colin Chapman disciple |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
I wondered that also....I don't tow my Yaris, but I do tow my '99 Rav4, all 4 wheels down. It has a digital odometer, and I need to have the ignition switch in ACC. to keep the steering from locking up. My guess is (havn't bothered to check, don't really care) the digital speedos don't work unless the engine is running?
#9 | |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 03:58 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| Towing Hitch for a Yaris | fmicle | General Yaris / Vitz Discussion | 1 | 05-16-2007 08:07 PM |
